Page 11 of 11 FirstFirst ... 2 3 4 5 6 7 8 9 10 11
Results 101 to 104 of 104
Thread: All about welders and welding
  1. #101
    Senior Member Casey-G's Avatar
    Casey
    Glued these bitches in today with the mig, completely gutted the doors notched them out n then welded the doors closed with a series of spot and stitches then welded the bars in.. 4door to coupe conversion
  2. #102
    Casey
    Here is a few more bits I've done in the past year that I have photos of:
    Spot welded every seam in the car
    Collector I made for the manifold & the manifold:
    Dump, dump&manifold:
    Exhaust:
    IC piping:
    Prepped and tacked:
    Welded and polished:
    Some welding I did for a customer, was on a GQ patrol for the exhaust
    And a bit I did on my current exhaust
    In every picture above except the patrol exhaust I used second hand material.. so it goes to show prep and fitment is everything.. and so are other things of course but its pretty important you spend the time cutting and making things fit before you weld.
  3. #103
    Adan
    Oxley Park
    Please tell me your filling in the rear doors from the outside too?
    Will look awesome!
  4. #104
    Casey
    There stitched in several places at present, will run around the doors with sealant before I actually fill in the the door sills..
  1. Tig Welders
    By willa in forum Tool Talk
    Last Post: 23rd March 2011, 08:20 AM
  2. what welding rods to use when welding a diff???
    By macca1590 in forum Technical - Questions
    Last Post: 14th March 2011, 10:36 PM
  3. welders flash
    Last Post: 10th August 2007, 12:41 AM
