Page 6 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 51 to 60 of 104
Thread: All about welders and welding
  1. #51
    Moderator Sam-Q's Avatar
    Endeavour Hills
    yes I used one and I found it couldn't do a single one of those things it was reported to do. I was however able to use copper as solder without flux on steel like it was lead/tin solder going on fresh copper. When trying to get help out of the guy all he could come up with is "but it should work", what a dick.
  2. #52
    Veteran hao.'s Avatar
    Hao
    South Brisbane
    What do you guys think about the Magmate 180P units the BOC sell? Any good? I did a bit of research and found mixed results, though most of the reviews leaned towards it being a good welder.
  3. #53
    Jan 2010
    Mahir
    Western
    Cooler piping, stainless, will require a TIG. Completely different welding style from a MIG/ARC. Depending on the person, some find it easier, some find it harder.
  4. #54
    Endeavour Hills
    I think if you know what your doing you could do some decent stainless cooler piping with arc/mmc, I would give it a go.
  5. #55
    Adan
    Oxley Park
    I reckon using an arc/mma welder would be slightly difficult for thin pipes, but certainly do-able.
    MIG would shit it in, even with ally.
    You wont do any spot welding unless you buy a spot welder though, completely different process.
  6. #56
    Apr 2011
    Gary
    Karalee
    just throwing this out there , it would be worth going out to your local tafe and sitting a few courses even prevo boiler making .
    its relitively cheap they will explain so much to you and it will make mig welding seemingly simple .
    they will make you run a series of fillet welds and teach you how to properly prepair and weld your material . well worth the money and time in my opinion
  7. #57
    Apr 2011
    Gary
    Karalee
    not true , i do all my intercooler piping with a mig welder . stainless to steel . i dont run welds i do a series of high powerd low feed tacks to get perfect penitration without leaving too much excess material . it takes a bit longer but looks like tig welded pipe and doesnt leak if you do it right .
    and if your fitting pipe work without pressure testing your a bit silly
  8. #58
    Endeavour Hills
    alright I am back on the forums
    you might find this funny I used some exhaust tubing (1.6mm mild) and welded it with an arc out in the street in the gutter, like literally, funny as but yes your definately right about being a bit difficult. However I completely disagree with you with the mig comment, I think mig welding thin aluminium would be very hard but I have only had limited experience.
    with intercooler piping I can't see having slight leakage as having any effect at all. I am sure many would loose more through the hose clamped areas.
  9. #59
    Adan
    Oxley Park
    haha thats awesome. I tacked a mates compete exhaust together on his front lawn with a little arc welder too, getting reasonable tacks while using no clamps is a fun process on grass.
    MIG welding thin aluminium is fine, but it really depends how your machine is setup. If you have a proper liner, and tips and everything is working on the day, it can be sweet. As swcustoms said, its more like doing a whole bunch of hot tacks than doing stitches.
    That being said, I still have a TIG and dont really feel the need to buy a MIG at all.
  10. #60
    Endeavour Hills
    ah I stand corrected then, from what I understand aluminium is very intollerant to poor or even mediocre feeding. Also I can see why you would find it hard to justify a conversion on mig with the cost of the drive wheels, liner, tip and different gas that's all needed.
  1. Tig Welders
    By willa in forum Tool Talk
    Last Post: 23rd March 2011, 08:20 AM
  2. what welding rods to use when welding a diff???
    By macca1590 in forum Technical - Questions
    Last Post: 14th March 2011, 10:36 PM
  3. welders flash
    Last Post: 10th August 2007, 12:41 AM
