Page 7 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 61 to 70 of 104
Thread: All about welders and welding
  1. #61
    Adan
    Oxley Park
    Yeah, aluminium wire seems to be quite touchy. You can get a few different grade wire spools though, which vary in how soft they are. The hard wire seems to go ok in a machine which isnt setup so well. But for the softer wire youd want either a proper push-pull gun or a nice short lead with a good condition plastic liner.
    Getting hot tacks on aluminium, I find, is similar learning to TIG weld aluminium. You need to get the right balance between being hot enough, but quick enough to not burn through it. While still trying to not get burn backs and clogging the tip (which will probably happen 50% of the time on an average machine)
  2. #62
    Jan 2010
    Mahir
    Western
    You sure can do it, but almost definatly the result of the weld will be at a much lower quality. Couldn't hurt to practice on scrap, or get a feeling of both types.. Then deciding on which to use.
    I'd just get used to the tig and use that. Garunteed penetration for the best weld almost garunteed.
  3. #63
    Moderator Sam-Q's Avatar
    Endeavour Hills
    I have to disagree with you there jet, if done right I see no reason why a arc weld could not be structually as good as a tig for something as simple as a 1.6mm thick pipe butt weld. Stainless is very nice to weld with an electrode and with the right current good penetration is a certainty. All that said it's not something I would readily recommend. I have an unopened 316 grade electrode grade pack, I should weld a bit of pipe with my untrained hands to show what I mean.
  4. #64
    Adan
    Oxley Park
    I agree with Sam-Q.
    Stick welding is probably one of easier ways to get better penetration, the problem is getting used to controlling it on the verge of blowing a hole.
    Speaking of stick welding too, I have no gas for my TIG at the moment, so Ive been tacking my whole front end with the stick. I bought a pack of supercheap brand electrodes (pack of 25 for 7 bucks), theyre one of the nicer electrodes Ive used. Ive been stitching 3mm steel to 1.6mm sheet, no holes blown yet. For some reason theyre just really smooth and are super easy to start.
  5. #65
    Endeavour Hills
    also I better mention it makes a massive difference between a traditional an electronic arc welder. The old iron core will just want to stick every time
  6. #66
    Aug 2010
    Sutho Shire
    i want to get a arc welder ,just to learn and stuff, i have no real experience,what sorta stuff and numbers should i look for?
    i want to learn to weld exhaust material and like sheet steel for like rust repair,front guards on to rears just the sorta car stuff to start with and what ever else.
    need a welder,rods and mask, any help appreciated
  7. #67
    Stern but now fucked off...
    May 2005
    Nick
    Buy a MIG....
    Lincoln SP170T / Tradetools SK175 (170amp)
    Get one with Gas.
  8. #68
    Endeavour Hills
    I agree with Nick, a gas sheilded mig is unbeatable for welding holes up and fixing rusty bits
  9. #69
    Aug 2010
    Sutho Shire
    thanks for that guys,what sorta rough prices are we looking at for the couple nick mentioned?gona have a look
    around tomorrow
  10. #70
    May 2005
    Nick
    Pricing from my memory only
    Lincoln SP170T = ~$1250+gas
    Tradetools SK175 = ~$728 +gas
    (copy of Lincoln SP170T and just as good)
    You'll do about 8mm thick steel with a 170 amp machine.
    Both can be setup with 0.6mm wire for panel work and then be swapped out to 0.8, 0.9, 1.0mm etc for thicker stuff.
    You'll pay less for gas wire because it doesn't have shitty resin inside it.
  1. Tig Welders
    By willa in forum Tool Talk
    Last Post: 23rd March 2011, 08:20 AM
  2. what welding rods to use when welding a diff???
    By macca1590 in forum Technical - Questions
    Last Post: 14th March 2011, 10:36 PM
  3. welders flash
    Last Post: 10th August 2007, 12:41 AM
