<3
I have no pics Marv!Post up a phone pic.
<3
fuuuuunk yeah! looks rad
You could go a bit lower and run a 5mm on the rear
Why are you selling? Keep the rims and put them on PS13
I'm not selling anymore.
The rear coilovers are as low as they go unfortunately. I need to do some more rear guard work so i can fit 5mm spacers, the tyres are about 3mm from metal atm. Damn those uncircular guards.
Also. I really hate that the exhaust is on the wrong side of the car, something will be done about this.
You can fix that easy.
Take a locking collar off if it's as low as it can go.
More low means more camber and you will be able to fit 5mm.
True that. wouldn't the whole spring / collar slowly adjust itself up & down if I took the locking collar out?
If I could make the rear a little bit lower it would work out awesomely too 'cos then I can drop the front to match as the front coilovers still have a bit of adjustment left.![]()
Nope, think about it.. It's just locked against the bottom, where usually just just another collar.
Looks amazing Hao!
perfect dude. not really bookable either
