you'll be fine with that for a while
hey guys I'm going to buy a sprinter and I want to use it for street and track what would I need to make it slide good? it has 4age, coilovers and that's all
you play halo?
add me GT: samnbhnc
EDIT
"Hi guys i want to be different and drift an ae86 cause drift king did it...my plan is to buy it and show it off to my mates and wrapped it around the first street pole i can find, please help me pull the hand brake"
anyways
if thats all its got then im assuming everything else is stock
lock the S series unless you can source out a T and LSD
maybe get a bit more lock to help stop with the spin out..
run good condition tyres up front and shitters on rears
practice, practice, pratice....just dont do dumb shit like ive mention above and wrap a beloved AE86 around a pole...they are rare as it comes already
dose
I'm sure this has been discussed heaps?
i dont plan on doing dumb shit i just wana know what i should do to mod it better for drift ?
lock the center and your sweet then =]
dose
Rice u scum bag leave the boy alone gotta b time for pizza n bends again soon..
anyway you will struggle if the diff is open center, if u have money buy an lsd, if not weld it up.
thats serioulsly all u need to get into it.
once u notice u might need something... thats when its time to change other parts
firstly what do you mean by slide good i was given some advice on my car and setup it was find a car here on ae86 dc that slides "good" and then copy the setup then you know it will slide good because you have seen it first hand if your going to copy an ae86 then look at robo"s rig
here some examples
blairs car
robos car
this helped me as i coppied ae71neo and i guess i can slide alright now another car would be bams_keto on here but he has a 4agze no matter you will be able to slide what you have but steering lock and a locker/lsd is a must have no matter what
power steering arms and an ajps lock spacer
welder
that should be your shpooing list for the moment but those things will last you a long time next is more power i hope this helped/helpes you
the dyno pull to 300rwkw
alright guys thanks for the advice
