Results 1 to 4 of 4
Thread: diffs???
    Senior Member MR86ER's Avatar
    May 2010
    Marcus
    Werribee
    Default diffs???
    hey guys new to the ae86 scene and just wondering on diff selections ive been hunting a t18 t series for the past 3 weeks at local wreckers but no luck i did manage to find a ta22 celica diff and was wondering if the t18 is the same diff as the ta22 can anyone help me
    cancling your subscription as a humanoid
    Mt Macedon
    No. The TA22 diff is narrower (definitely) and also has some different mount points (allegedly, never had them side by side). Also double check it is a T series since some early TA22s came with a different (D series from memory) diff.
    You can use the T series centre, but that's about all.
    And please take the time to include some punctatuion and capitals in your posts. It make things easier to read and people more likely to answer. Your spelling, however, is above reproach.
    Veteran johl's Avatar
    Johl
    ra40 is ur friend
    Moderator Sam-Q's Avatar
    Endeavour Hills
    TA22 is 1370mm wide unlike the 1410 of the ae86
  1. diffs
    By rolla92 in forum Technical - Questions
    Last Post: 25th April 2009, 05:28 PM
  2. Diffs?
    By jamekins in forum The Drift Channel
    Last Post: 2nd January 2009, 10:33 AM
  3. diffs diffs diffs
    By ae71 drifter in forum Technical - Questions
    Last Post: 21st September 2007, 01:46 PM
  4. Diffs
    By s-jyusan in forum Technical - Questions
    Last Post: 17th June 2006, 06:20 PM
