SP-Tec make them as a kit with tension rods.
im trying to get ahold of some caster arm brackets/rods like the ones cusco make, does anyone know if any other company makes them other than cusco?
P.S. sorry if this is in the wrong section, feel free to move
Dillon
t3 make them, go look in the spirited drive thread
~KEEP DRIFTING FUN~
sptech make them aswell...other than that i cant say ive seen any
MY AE86 BUILD
yeah im looking for ones like at the top with the whole new bracket, not the T3 ones which just have an adaptor for the old brackets. you guys know where i could get my hands on some for less than 500 landed?
No where, save and buy cusco
those sp-tec ones look quite decent
not even remotely similar
MY AE86 BUILD
yeah no not like T3 one - to be honest, what is the benifit of replacing the K frame bracket?
if your going to do that save up and get the Cusco setup with the new placed inner castor rod mount on the LCA - 2 bolts are replaced with a spheical bearing on the front side of the LCA.
The above conversion seems pointless
so you can take your sway bar on and off without taking the brackets off and threading them over causing your alignment to go wack.
also they are stronger, in my more abusive streeting days i snapped mine off on the front from the support in my red car.
wheelfriends.wordpress.com
