grill + hacksaw? i've wondered this myself...
Hey guys,
how does everyone do it? post pics of your setup.
Robo
Well most kouki lights have foggie brackets at standard (in the event of having the foggies as an option) So just drill two small holes into the top of the grill in the same location as the brackets......Apply zipties liberally....And there you have it.....The BEST front end combination for a LEVIN
And if you have a sweet tooth....Include a Zenki Levin badge as the Cherry ontop
I guess my txt explanation made no sense to you? haha. I'll dig around for pics for you man.
I'd probably make up some small alu L brackets, sikaflex them on to the headlights, and apply zipties as above. (pretty much acticing like the foglight brackets would)
I was just going to make some straight brackets, bolt them to the grill with those low-profile round headed bolts, and then run a small nut and bolt on the foglight brackets. It looks like it will have it at the perfect height too
Basically, a sturdier version of what MINIHORSE suggested.
I used zip ties
zenki grille with kouki lights is the best combo
pic of this said combination??
Old username : hally
Beige build in the works!!
http://www.ae86drivingclub.com.au/fo...426#post874426
