i reckon it will be 1.1mm,could be wrong but it will run fine at that setting.
Can sometime tell me the actual recommended spark plug gap for a Kouki Bigport 4AGE?
Stock motor.
Thanks, Ben.
1.1mm is correct.
Ive used everything from 0.8 to 1.3 before, they all worked fine. Especially with copper plugs.
I've been running 0.8
Thanks guys
yes the champion copper plus plugs are good but you need to change them regular, i swear by ngk.
