you should be able to use an ADM section of a loom as i think they have that all seperate
I have a kouki dash and kouki front loom, but no engine loom.
I didn't think this would be much of a issue initially as I'm using a Adaptronic ECU but after getting down and dirty I realised that unlike zenki or adm the kouki loom puts the starter, reverse lights, oil pres, water temp, wiper and washer wires in with the engine loom!
So I want to make up a section of loom just for those parts as the Adaptronic loom handles the rest of the engine side of things.
I have all the correct plugs, but I just need to connect all the pins in the correct place.
Does anyone have a kouki wiring diagram, pinout, anything? That will tell me what pin is what?
Yes it does. I just need to workout which wires/pins to connect them to in the passenger side kick panel box.
Yeah I had a quick crack at it. But couldnt find em
