Page 10 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 91 to 100 of 102
Thread: s13 front coilovers into 86/*e7*
  1. #91
    Junior Member 4agte Ke70's Avatar
    Jul 2011
    john
    PW
    Default cracker thread
    cheers for the info, just done it to my ke70. =)
  2. #92
    Jan 2011
    Phil
    ACT
    Gordon
    Digging this thread up again... When using SR brakes what booster is best to use? S13? I don't want to be redrilling the firewall or re-routing brake lines if possible.
  3. #93
    Best to use or suitable to use?
    I always run standard.
  4. #94
    Jan 2011
    Phil
    ACT
    Gordon
    Which is best to use without needing to redrill the firewall and rerun brake lines. By standard do u mean standard for ke70 or standard for s13? Will the s13 booster bolt to the firewall in a ke70 without drilling new holes?
  5. #95
    Jan 2011
    Phil
    ACT
    Gordon
    So basically I'm after a 15/16ths brake master cylinder (not booster, my bad) with the ports in a similar location to the ksev
  6. #96
    I use the standard KE70 master.
  7. #97
    Jan 2011
    Phil
    ACT
    Gordon
    Are you running SR20 or CA18 brakes?
  8. #98
    SR20DET in my old KE70.
    SR20DET up front and VS commo rear in my two 86's.
    All standard masters.
  9. #99
    Jan 2011
    Phil
    ACT
    Gordon
    Cheers mate thanks for the help
  10. #100
    Feb 2012
    AJ
    Arizona
    Tucson
    USA
    Awesome, awesome info. This thread is the reason I joined this forum. One disappointing bit is that nobody has posted pics of an entire setup showing:
    A)Castor Rods
    B)Swaybar (installed)
    I was not sure if RA40 outers/inners was the answer but now I got it. All i have to figure out is which castor rod to use.
    I am using Tanabe Sustec Pro coilovers and a modified spindle for more angle:
    Keep the info coming.
  1. s13 front coilovers
    By shaunpierre in forum Nissan Parts For Sale / Wanted
    Last Post: 10th November 2012, 01:33 PM
  2. full s13 front conversion for 86/ke-coilovers and brakes
    Last Post: 14th May 2012, 10:42 AM
  3. WTB: S13 Front LCA's and S13 Coilovers. MONEY WAITING
    By luke641 in forum Cars or Parts Wanted
    Last Post: 15th February 2012, 01:13 PM
  4. S13 LCA's S13 front coilovers and AE86 rear coilovers
    By Brendan in forum Cars or Parts Wanted
    Last Post: 8th April 2010, 01:11 AM
  5. s13 front coilovers
    By 86adz in forum Cars or Parts Wanted
    Last Post: 15th December 2007, 11:14 AM
