if you use a high offset wheel like the suspension design was aimed at you get a much better situation
even at the worst s13 is doable and if you think it through it can be a good effective setup.
didnt michelmore use trd inserts in his s13 strut and make the coilover that way? same as toyota guys?
imo, the hsd i have work very well and the modded knuckles also remove the binding the system develops at full lock.
