Page 10 of 17 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 LastLast
Results 91 to 100 of 161
Thread: S and T series diff info
  1. #91
    Veteran anastasios's Avatar
    Taz
    Earlwood
    hey guys, what is the rear sway bar diameter of ADM ae86?
  2. #92
    Dec 2011
    Kerry
    Warradale
    anyone have info about AE85 S-series?
  3. #93
    Senior Member s14seriesII's Avatar
    Mark
    Southern
    Ae85 S series in theory is exact same as our adm S series
    Owner built and tuned 9000rpm 402kw atw 3sGTE - AE86
    Quote Originally Posted by Beau View Post
    4ages are for the scared
  4. #94
    Dec 2011
    Kerry
    Warradale
    have heard rumours of them having the same size drums as t-series...either that, or do t-series drums bolt on to s-series?
  5. #95
    Mark
    Southern
    I'm pretty damn sure I've put t18 drums onto S series brakes.. So yes.. That was a round about way of asking it though ?
  6. #96
    Dec 2011
    Kerry
    Warradale
    little bit...im just pissed at myself for being lemon'd...wasnt even thinking when i got it
  7. #97
    Dec 2011
    Kerry
    Warradale
    so...ra40 t-series...just want to clarify...
    it bolts in no worries, without pinion angle change?
    spring seats are fine to use with ae86 springs?
    does the panhard rod need to be a special length, or will a normal adjustable ae86 item do the job?
    and obviously an ae86 lsd will fit into the ra40 center?
    thanks for bearing the painful questions
  8. #98
    May 2013
    South Australia
    any answers for the above questions?
  9. #99
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    I personally haven't tried it, but my understanding of the RA40 diff into an E7 or 86 is that the trailing arm mounts are a little different in their location, but they can be squeezed in. You'll just flog out trailing arm bushes quicker.
    I think the spring perches may be smaller too.
    They aren't a bolt in drive away afair. Nothing is, unless it came from an AE86 to begin with.
    Even E7 diffs are different in their hand brake cables, so aren't a perfect fit.
    A Zenki AE86 LSD will fit an RA40 centre.
  10. #100
    Senior Member billett86's Avatar
    Mar 2010
    Toby
    Adelaide Hills
    anyone know of anywhere to get the anti vibration clips that come out of a jdm t series and that go between pad and caliper?
  1. F series Diff info + Discussion
    By Konakid in forum Technical - Articles
    Last Post: 6th July 2019, 01:34 PM
  2. G series Diff info + Discussion
    By PRIMRK in forum Technical - Articles
    Last Post: 25th July 2014, 02:41 PM
  3. info on fitting rear 86 calipers to series 1 T18 diff
    Last Post: 29th April 2012, 02:46 AM
  4. Info on F series diff ratios above 4.3
  5. prize for this answer! s series diff info
    By styler in forum Technical - Questions
    Last Post: 28th November 2006, 01:50 PM
