really? odd
i know thats the case with t series into 86...have done it into 71 and it was the same deal
Its shorter?
That'll make the problem worse then.
The AE86 cables wont reach the E7 front section.
really? odd
I fitted a Celica RA60 banjo in my KE70. All the differences are here-
Will a front 4wd tarago cr+p fit a t18 diff? Its from a auto, any idea on ratio
Will fit if its T series
Think from memory 4:5?
The gear set from the lite ace (4.5) will fit any T series centre.
I'll just add a note there, a liteace gear set will fit. But only from the front diff of a 4WD one.
I don't believe any tarago's had as small a diff in the rear as a t series.
We should sticky seal part numbers like pinion and axle seals. I've been doing my balls on finding them. Bursons are hopeless and already got me the wrong parts.
Hopefully bearing wholesalers gets it right
Had a search that gave no answer, i have a drum t series with a 2way in my 86, im unsure what the t series came from,problem is i want to order some new drums, shoes, do all t series have same brakes so i just ask for t18 gear or are the brakes same as a s series?
Depends what the width is, if its 1410mm wms to wms then its probably t18, if its 1380mm its ra23/28, or 1440mm then ra40, from memory the ae86 s series drums are different but still interchangeable I believe, the wheel cylinders are the same and I'm pretty sure the shoes are the same
