provided it is a T18/AE86 t series...
drums
shoes
wheel cylinders
handbrake cables
that took all of 2mins searching on ebay to find those
Thanks mark il give it a measure, is there anyone out there that can confirm ae86 s series shoes will fit and work in a t series? Thanks
drums
shoes
wheel cylinders
handbrake cables
Wasnt asking where to buy from, asking are all t series brakes the same and will s series shoes work in t series drum, cant find sizes online, dose the celica , t18 t series share same brakes
Hey. Just to let you know, none of those links even work.
Current Cars:
1974 Mazda 808/RX3 Sedan (In Storage)
1983 Toyota Trueno AE85, 20V B/T (In Storage)
1983 Toyota Starlet KP61 Wagon (In Storage)
1982 Toyota Corolla KE70, Quad Lights, T18 Chrome Bumpers, JDM T-Series, Factory 4K (Daily In GC)
1983 Toyota Starlet KP61 'Lisse' (Soon To Be Daily)
Having a look at genuine toyota part numbers and the aus spec t18/te72 and the aus spec ae86 rear shoe kit share the same part number so I guess they are the same.
Toyota part number
Shoe kit, Rear brake 04495-14010
Current Cars:
links work fine to me...
Yea works in ebay iPhone app. Just not in safari on iPhone.
Thanks.
Current Cars:
Ok so for people in the future you can order brake shoes for adm ae86 and they are identical to shoes in a t series as i bought and installed today,i have a part number for shoes and front pads ill post tomorrow ,shoes were in stock too but front pads are special order
Just like to add in that don,t forget about RT104 corona for t series stuff. From 75 to 78 all run t series ( and later but do change amongst models and variations like wagon, luxury ,etc) with many different ratio,s( 3.9, 4.1, 4.4 are ones I have come across) zenki size axles with drum brake. For an easy disc upgrade ST141 girlock bolt straight on incl handbrake ( not t series) so hope this may help sourcing cheap parts. Pretty sure from memory 1410 mm but don,t quote me but can double check if anyone requires. Hope this helps someone out.
Pretty sure from everything I have read online st141 rear disk assembly's require a spacer ring to fit the rear end.
4.4 ratio t series diff center sounds good. Will start looking for one of them.
Anyone know if the speedo calibration goea out when changing from 4.1 to 4.3 or 4.4?
