Page 14 of 17 FirstFirst ... 4 5 6 7 8 9 10 11 12 13 14 15 16 17 LastLast
Results 131 to 140 of 161
Thread: S and T series diff info
  1. #131
    May 2013
    South Australia
    yes the speedo calibration will go out...much the same as going with different sized wheel tyre combos affect it
    and yes, you do need to run a spacer inbetween the bearing retainer plate and bearing for the disc upgrade
  2. #132
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    Yeah speedo will be off. Golberg sells the different speedo gear combinations to fix it though.
  3. #133
    Junior Member PRP120's Avatar
    Jul 2013
    qld
    sunshine coast
    Yeah sorry. AE will require spacer ring, straight forward for me as same size through out coronas(60mm). My bad....was in corona mode. Yeah ratio does change speedo. I've swapped speedo drive pinions/gears each time to suit. Corona 4 speed n celica 5 speeds(steel case) are exactly same so all good. From memory the 4.4 was from a 76 RT 104 manual wagon CS. Pretty hard to find.... Most are 3.9 and who knows if they hadn't tinkered with before I got my paws onto it.
    RT104 Corona, 12A turbo rotary, Celica steel case 5 speed, bigger brakes... Actually not much standard stuff left....can I still call it an RT 104? Yes cause it's still mustard gold!!
  4. #134
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    4.4 seems an unlikely ratio, never heard of it before. You can definitely get 4.1 4.3 4.5 4.7 4.9 5.1 5.3.
    Anything above 4.7 is not a Toyota OEM part, TRD ones exist as do other brands.
    Speedo is definitely effected by a diff ratio change, I sell the parts to correct your speedo in the event of a diff or tyre change: !
    EDIT: Didn't see all the replies already, thanks guys!
  5. #135
    Veteran anastasios's Avatar
    Taz
    Earlwood
    Hey guys,
    when installing axles do you grease/oil any of the bearings/seals?
  6. #136
    Lawrence
    Wollongong
    The bearings on the axles are usually sealed so you can't actually oil them.
    I'd put a wipe of oil around the seals.
  7. #137
    Taz
    Earlwood
    Does anyone know the part number for AE86 sway bar bush 14mm bar, Ive got a pair of super pro bushes and pedders bushes and they both dont fit. They are too big for the u bracket
  8. #138
    Feb 2012
    Bob
    West
    This might help someone out - T series outer oils seals (axle end) are kelpro 97079, 52x65x9. I just bought a couple so I know they are right
  9. #139
    Lawrence
    Wollongong
    Just as an aside, I'd strongly recommend staying away from after market oil seals.
    I've installed plenty and wont every do it again. They often weep (due to a lack of oil direction fins) and usually fail much quicker than genuine items.
  10. #140
    Feb 2012
    Bob
    West
    bugger, thats good to know - can you get a couple of genuine ones for me???
  1. F series Diff info + Discussion
    By Konakid in forum Technical - Articles
    Last Post: 6th July 2019, 01:34 PM
  2. G series Diff info + Discussion
    By PRIMRK in forum Technical - Articles
    Last Post: 25th July 2014, 02:41 PM
  3. info on fitting rear 86 calipers to series 1 T18 diff
    Last Post: 29th April 2012, 02:46 AM
  4. Info on F series diff ratios above 4.3
  5. prize for this answer! s series diff info
    By styler in forum Technical - Questions
    Last Post: 28th November 2006, 01:50 PM
