Page 16 of 17 FirstFirst ... 6 7 8 9 10 11 12 13 14 15 16 17 LastLast
Results 151 to 160 of 161
Thread: S and T series diff info
  1. #151
    Mt Macedon
    In this situation I'd recommend a T18 diff housing (or another T series that can be made to fit, RA40??) and Corona discs. Cheaper, more available, better handbrake, maybe even slightly larger discs (can't remember off the top of my head).
  2. #152
    Mar 2011
    Ali
    I ended up buying a drum brake series 1 T18 T series that came with the shaft and hand brake cables.
    Is there a thread on the Corona Disc conversion?
    Like what model Corona, how to step by step.
  3. #153
    Mt Macedon
    Have a look at -
    The guy who starts the thread is a bit hardline about what you must do. But there are several options for a lot of things. Basically it's close to bolt up. You need to move your lower shock mount, have some form of bearing spacer ring and shorten the handbrake cables and there are multiple ways to do each. I think I even used the stock bolts to hold the backing plate on.
    With the stuff in front of you it'll be easy to work out what's best for you.
  4. #154
    Mar 2011
    Ali
    My Anti Virus does not like Toymods at all.
    Usually I can't get it to work, but I can view the link posted, but only in some kind of basic vBulletin
    Cheers for that!
  5. #155
    Rob
    Armidale
    I m trying to work out which liteace had t series diff ?
    From what i read its the front diff of 4wd liteace,which would be a 4.77 ratio?
    Never seen or heard of one,could any one confirm .Year and model would be great.
    Rob
  6. #156
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Any 4wd liteace will have a T-series front diff. I've pulled out 2 of them. One was out of an 89 model, the other a 93. Both diesel 4.55 out of one 4.77 out of the other.
    These vans are very rare in Australia as they are grey imports.
    I don't rate your chances in finding one though. Mind you I did find 2 over the past 5 years.
    Oh, and they are an absolute menace to get out.
  7. #157
    Mar 2011
    Ali
    Sedan sorted, thinking about the Van now.
    Quick question,
    Is there a leaf spring version of T series?
  8. #158
    Rob
    Armidale
    Thanks Goldberg I went to my local toyta dealer looking for a 4.77 c&p which are still listed but retail over 1000 ,and trade 800 sum thing.
    F##k that !!
    I emailed wier but as normal no reply.
    Looks like im heading for G series,not going to pay bs prices like that.
    Thanks for info Rob
  9. #159
    Oct 2010
    Dogan
    Tulla
    What tail shaft would I use for a S series diff in a Ke70 with a K50 gearbox??
  10. #160
    Senior Member ae86 drifter's Avatar
    Pete
    ok so I've read some of the pages but just wondering if the t series disc 86 diff is offset to one side of both axles the same length?
    ROYAL GARAGE NEWCASTLE
  1. F series Diff info + Discussion
    By Konakid in forum Technical - Articles
    Last Post: 6th July 2019, 01:34 PM
  2. G series Diff info + Discussion
    By PRIMRK in forum Technical - Articles
    Last Post: 25th July 2014, 02:41 PM
  3. info on fitting rear 86 calipers to series 1 T18 diff
    Last Post: 29th April 2012, 02:46 AM
  4. Info on F series diff ratios above 4.3
  5. prize for this answer! s series diff info
    By styler in forum Technical - Questions
    Last Post: 28th November 2006, 01:50 PM
