Page 3 of 17 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 ... LastLast
Results 21 to 30 of 161
Thread: S and T series diff info
  1. #21
    Veteran hachi_dk's Avatar
    Filip
    Jozzaville
    what cars come with the diff your talking about?
    80's supras?
    because i need to find one thats 5 stud as your saying; as my ae's 5stud.
  2. #22
    Senior Member s14seriesII's Avatar
    Mark
    Southern
    the lsd hemisphere makes no difference to how many wheels studs you have it doesnt even make any difference to the diff ratio your using, but im pretty sure all vehicles fitted with a g series are either 5 or 6 stud and all the models mentioned are also irs, which again makes no difference to your car
    Owner built and tuned 9000rpm 402kw atw 3sGTE - AE86
    Quote Originally Posted by Beau View Post
    4ages are for the scared
  3. #23
    Dave
    jsut thought id let you guys know
    KE70 + S series = ADM 86 or JDM 86 front half + ADM 86 rear half
    KE70 + T series = same as AE86 with T series
    this doesnt work with K motors. (or specifically K gearboxes, k40 or k50)
    you cannot join a front K gearbox tail shaft to a rear ae86 tailshaft (S or T). and the front 86 tailshaft wont fit into a K gearbox.
    86 tailshafts can be spit via a flange, but ke70 ones cant be. they can be split but its via the uni joint. so its different.
    believe me i tried it. luckily i tried the tail shaft before putting the diff in!
    - Blaise Pascal
  4. #24
    Filip
    Jozzaville
    im just asking what diffs are 5 stud. never said anything bout the hemisphere or diff ratio
  5. #25
    Mark
    what about ae71 tailshafts??
    Are they the same as adm ae86?
  6. #26
    Filip
    Jozzaville
    do kouki lsd's have 23/24 splines while zenki 22?
  7. #27
    Veteran ae86's Avatar
    Dave
    Western Suburbs
    zenki and kouki axles/lsds have same amount of splines, its just the diamatre's are different
  8. #28
    Dave
    hmm im not really sure, i cant remember if it had a flange like a 86 one has.
    if i remember ill have a look under my car tomorrow.
    - Blaise Pascal
  9. #29
    Kieran
    can anyone tell me what ratio s-series diff came stock in adm ae86's?
  10. #30
    Veteran hao.'s Avatar
    Hao
    South Brisbane
    ^ 3.9 I'm sure.
  1. F series Diff info + Discussion
    By Konakid in forum Technical - Articles
    Last Post: 6th July 2019, 01:34 PM
  2. G series Diff info + Discussion
    By PRIMRK in forum Technical - Articles
    Last Post: 25th July 2014, 02:41 PM
  3. info on fitting rear 86 calipers to series 1 T18 diff
    Last Post: 29th April 2012, 02:46 AM
  4. Info on F series diff ratios above 4.3
  5. prize for this answer! s series diff info
    By styler in forum Technical - Questions
    Last Post: 28th November 2006, 01:50 PM
