Page 5 of 17 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 ... LastLast
Results 41 to 50 of 161
Thread: S and T series diff info
  1. #41
    Nichy
    Launceston
    i didn't think that a t-18 shaft would go into a 4k box.... dont t-18's run t50's ?
    or will it just fit lol
  2. #42
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    The series 1 is important in the tailshaft, series 1 T-18s run an earlier style T50 with less splines, same as KE70 I have been repeatedly told.
    Series 2 T18 on the other hand has the same T50 as an AE71 or AE86.
  3. #43
    Nichy
    Launceston
    ah well thanks for clearing that up
    cheers guys
  4. #44
    Veteran ae86's Avatar
    Dave
    Western Suburbs
    anyone knows part number for T series axle seals?
  5. #45
    Nichy
    Launceston
    t-18's series one run a 20 spine tail shaft same as a ke70
    just for the info lol
  6. #46
    Veteran blair's Avatar
    Blair
    SEQ
    I'd like to queery this... i have what i beleive to be an RA60 Diff, and yes the trailing arms are off by a bit, and the spring seats are smaller. However they are MUCH smaller, to the point i do not see it safe to use AE86 Springs. Mine is also 1430mm, about 10mm Wider each side than AE86! Do i have a different differential than thought??
  7. #47
    Senior Member s14seriesII's Avatar
    Mark
    Southern
    well i know for a fact that ra40 uses the same t series centre and axel splines but its 1430~1440 mm wide and spring seats are very close to ae86 (close enoguh not to worry about) so if you are sure its a t series it could well be the ra60 diff...
    Owner built and tuned 9000rpm 402kw atw 3sGTE - AE86
    Quote Originally Posted by Beau View Post
    4ages are for the scared
  8. #48
    Hair model Jacobxxx's Avatar
    Jacob
    Sunshine Coast
    anyone know specs on ra60 diffs?
  9. #49
    Blair
    SEQ
    Yep refer to your other thread...
  10. #50
    Member CoR*'s Avatar
    Corey
    GOLD COAST
    Ok so im getting hold of a t series from a TA22 to put in my adm 86...
    Ive read that the axles are shorter in TA22's??? Think if i got zenki ae86 axles... and transplanted my mounts / trailing arms from my s series would that work?
  1. F series Diff info + Discussion
    By Konakid in forum Technical - Articles
    Last Post: 6th July 2019, 01:34 PM
  2. G series Diff info + Discussion
    By PRIMRK in forum Technical - Articles
    Last Post: 25th July 2014, 02:41 PM
  3. info on fitting rear 86 calipers to series 1 T18 diff
    Last Post: 29th April 2012, 02:46 AM
  4. Info on F series diff ratios above 4.3
  5. prize for this answer! s series diff info
    By styler in forum Technical - Questions
    Last Post: 28th November 2006, 01:50 PM
