Page 8 of 17 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 LastLast
Results 71 to 80 of 161
Thread: S and T series diff info
  1. #71
    Veteran johl's Avatar
    Johl
    I'm not sure. I have used both and didn't notice a difference. So they must be either the same or pretty close for me not to notice
  2. #72
    Senior Member odessy's Avatar
    Blake
    Qld
    Bris
    So an LSD for a t18 will fit in the ra60 rear end?
  3. #73
    Hair model Jacobxxx's Avatar
    Jacob
    Sunshine Coast
    Ah okay, friend had an ra60 t series in his ke70 and couldn't even fit 13x7 +-0 on standard guards.
  4. #74
    Senior Member s14seriesII's Avatar
    Mark
    Southern
    yeh the ra40/60 diff is about 30mm in total wider.. so 15mm a side..
    and the upper trailing arm bolt holes are not in the correct location.. it still bolts in fine but you will find that the pinion angle/flange is pointing up at a fair rate,
    for lowered ae's ke's this means the tailshaft rear uni joint and flange will rub the floor far more often
    Owner built and tuned 9000rpm 402kw atw 3sGTE - AE86
    Quote Originally Posted by Beau View Post
    4ages are for the scared
  5. #75
    Glenn ke_70's Avatar
    Clay
    Barossa!
    also i think the diff sits abit further towards the rear. i have many clearence issues with my ra60 diff. if you want big wheels just go for a normal corolla t series.
    also the spring perches are different, trailing arm are drilled 14mm, and they're ugly ratios too. 3.9 man 4.1 auto
  6. #76
    Mark
    Southern
    lol yes all true..
    and ugly ratios.. lol
    ive got a 3.9 in my restored ae86 street car and a 3.7 to go into my daily but i do like fuel economy !
  7. #77
    Blake
    Qld
    Bris
    What about the USDM te72?
  8. #78
    Clay
    Barossa!
    what about them?
  9. #79
    Blake
    Qld
    Bris
    lol, they come with a t series aswell? Did any come with a factory LSD?
  10. #80
    Blake
    Qld
    Bris
    Anyone know what diff the USDM te72 came with?
    Also what is the go with swaybar mounts when changing to a t series?
  1. F series Diff info + Discussion
    By Konakid in forum Technical - Articles
    Last Post: 6th July 2019, 01:34 PM
  2. G series Diff info + Discussion
    By PRIMRK in forum Technical - Articles
    Last Post: 25th July 2014, 02:41 PM
  3. info on fitting rear 86 calipers to series 1 T18 diff
    Last Post: 29th April 2012, 02:46 AM
  4. Info on F series diff ratios above 4.3
  5. prize for this answer! s series diff info
    By styler in forum Technical - Questions
    Last Post: 28th November 2006, 01:50 PM
