Page 3 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 21 to 30 of 51
Thread: random little projects
  1. #21
    Gunner
    I think the tractor parts suit the SR hahaha.
    You are one clever cookie dude. Good stuff.
  2. #22
    Veteran Skylar's Avatar
    Ken
    Thanks dude, means a lot to me coming from you.
    Sweet ride huh?
    I also got a merge collector lookin thing I made up laying around that I need to cut and weld the turbo flange onto. Then comes the making of the turbo manifold.
    Onto another matter. The corolla has a shortened tarago F-series in it. The re-splining job was good and fit perfect into stock diff with no play. The same axle put into an IS200 cusco LSD is loose. There's about 7 or 8 degrees of play. Is this normal for cusco?
  3. #23
    Veteran biggo's Avatar
    Nick
    Noosa
    thats weird. Is it loose in the slpines or in the center?
  4. #24
    Ken
    The splines.
  5. #25
    Ken
    Collector's cut, CAD is down at water cutter. Manifold starts when I get flanges.
    Accidentally dropped a ziptie in the timing chain area of the SR. I bid it farewell, put the motor back together and drove it. Guess I should take the oil pan off some time and see what happened to it.
  6. #26
    Veteran Nikkojoe's Avatar
    Tom
    Ziptie is nothing. Found a bolt in a 4ac sump and it wasn't because the motor let go
  7. #27
    Ken
    Update, sort of.
    Made this:
    SR20 Valve height measuring tool. Saved a supposed 800 bucks in not buying the Nissan SST.
    Made half a collector... with an angle grinder. I need a band saw. and a belt sander.
    Ordered an ECU too. Should be here next week and running within a month or something.
    I put a layer of matte on the shroud to strengthen it as it was floppy like a flexible side skirt. Test fit it and clipped a corner out of and re-glassed it. Mate has it now and should be bogged and smooth by now.
    Swapped front housing on a Nissan 5 speed.
  8. #28
    Ken
    Bad idea? Maybe, maybe not.
    Got the ECU to read a bunch of pulses coming from the CAS after trouble shooting for a good day. In the end there was nothing wrong, wasn't my fault, just the software telling me to do crazy shit. Running tomorrow??? Then weld the bung into the downpipe and finish off the collector while I got the welder out.
  9. #29
    Ken
    and now it runs.
    I should probably elaborate. That silver thing with the DC37 connector is a Megasquirt V3 ECU. It's a build it yourself mainboard with plug in chips(MS1) or daughter boards(MS2 or MS3). I've got an MS3 which supports USB communications, SD card datalogging and with the other board connected to it with ribbon cables is the expansion board for 8 injector drive and 8 spark outputs(need ignitors or coils with built in ignitors) and a second crank/cam input.
    Supports boost control, nitrous, water injection, air con, stepper motor or PWM idle valve, table switching, flex fuel, launch control, datalog off a button on dash, progressive retard limiter with hard fuel or ign cut. Spare channels become extra outputs for whatever. Has CANbus to talk to trans controller, display devices or external in/out boards. Datalog everything you want.
    All for under 500USD. I made a patch loom so everything is full plug in.
    Also, that beer in the above pic ain't mine.
  10. #30
    Ken
    Oil cooler crap:
    I got one of these too but not for silvia. I'll probably make something that interfaces with the megasquirt rather than fitting a stand-alone system.
  1. Anyone got other projects on the go?
    By GzePwr in forum General Topics (No Technical Questions)
    Last Post: 9th December 2007, 10:55 PM
