Page 11 of 16 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 LastLast
Results 101 to 110 of 152
Thread: Your Suspension Setup
  1. #101
    Senior Member MR86ER's Avatar
    May 2010
    Marcus
    Werribee
    Car: Hachi
    Car use (e.g grip/drift):daily/dori gets the girls
    Front Struts:AE86
    Spring Rate/ Free Height: 8kg king lows
    Inserts (brand/model):koni sports adjustable
    LCA's: stock
    RCA's (size if you have them): T3 30mm
    Strut Tops: T3
    Front Sway Bar: Whiteline 24mm blade adjustable
    Castor Arms:stock
    Rear Springs: 6kg king lows
    Rear Shocks: Koni sport adjustable
    Panhard Rod: whiteline
    Pro's: nice and stiff ok for daily use
    Con's: needs more low
    cancling your subscription as a humanoid
  2. #102
    matt
    vic
    knox
    wooo, stock everything with some king springs fixed up by an angle grinder!!
  3. #103
    Veteran AJPS's Avatar
    Lonsdale
    ^ and how is that working out for you?
  4. #104
    matt
    vic
    knox
    every time i make it around a corner alive, its a good day lol
    the massive slop in the steering is more concerning though......
    i'll get around to it one day.
  5. #105
    Veteran drift kid's Avatar
    Glossodia
    Car: AE86
    Car use : daily, odd drifting
    Front Struts: ae86 struts, shortened to suit ae92 inserts using HSD coilover kit.
    Spring Rate/ Free Height: 7kg/mm
    Inserts (brand/model): KYB excel G AE92's
    LCA's: GH sigma
    RCA's (size if you have them): 40mm AJPS
    Strut Tops: Standard Toyota
    Front Sway Bar: Whiteline 24mm adjustable.
    Castor Arms: Standard.
    Rear Springs: Standard cut.
    Rear Shocks: standard.
    Panhard Rod: Standard, custom adjustable using specially made adjustor peices.
    4 Link: standard.
    Bracing: cusco front strut brace, custom rear strut brace made my me.
    Pro's: Handles great, the 7kg/mm springs are perfect for daily and occasional track use.
    Con's: The large ammount of negative camber up front can be a burden sometimes though as i have a feeling its making the car understeer a little during hard cornering. The rear could also be stiffer to help for skidding.
    Extra Comments: The shortness of the AE92 front inserts allows for massive drops in ride height and the camber looks sick lol
  6. #106
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    dont forget the -5.17 degree's of camber ben HAHAHAH
  7. #107
    Tim
    Unley
    I swear any post that drift kidd makes you HAVE to comment it after with some useless comment.
  8. #108
    Lonsdale
    I thought I was the only one that noticed.
  9. #109
    Dave
    my suspensions:
    front:
    jap 86 calipers with vented slotted discs
    6kg springs
    sw20 excel G rear shocks, in 86 struts, converted to coilovers
    40?mm RCAs
    camber tops
    strut brace
    non powersteering arms
    rear
    adj panhard
    343113 KYB excel G shocks
    cut standard springs (so prolly 3-4kg)
    stiffer bushes in trailing arms.
    positives: good setup, turns in great,
    cons: brakes overheat on hard mountain drives, need to get PS arms. shocks arent the best, but they were cheap and do the job.
    - Blaise Pascal
  10. #110
    Lonsdale
    what pads/fluid you running?
  1. (SA) *E7*/86 BC/AJPS Rear Suspension setup/ 2871r turbo setup
    By sleeper_13 in forum Car Parts For Sale
    Last Post: 25th July 2012, 01:06 AM
  2. Need Help With Suspension Setup
    By ArbPotatoes in forum Technical - Questions
    Last Post: 30th June 2009, 10:51 PM
  3. ke70 suspension setup
    By biggo in forum Car Parts For Sale
    Last Post: 9th January 2008, 12:16 PM
  4. WTB::: suspension setup
    By winslow in forum Cars or Parts Wanted
    Last Post: 16th August 2007, 04:53 PM
  5. suspension setup
    By AE86_4life in forum Technical - Questions
    Last Post: 1st November 2006, 08:43 PM
