Continuing on from this, although I've yet to drive it the car has...
Car: AE71
Car use (e.g grip/drift): hills/drift
Front Struts: AJPS Coilovers
Spring Rate/ Free Height: 8KG/Unsure quite low.
Inserts (brand/model): Bilstein
LCA's: XT130 changed from the Sigma LCA's it used to have, they suited their purpose in achieving epic lock but they weren't really suited to street driving, the camber tops were set to full positive and even then there was still a bit of negative camber, 15x8's would poke a shit load under flared guards.
RCA's (size if you have them): Still none
Strut Tops:Tein adjustable
Front Sway Bar: A fair bit thicker but I'm not sure how thick, 15mm maybe.
Castor Arms:stock
Rear Springs: AJPS 6kg/mm 215mm free height may chop off a coil or so because it's a little too high in the rear.
Rear Shocks: Boge Turbo shocks,
Panhard Rod:AJPS
4 Link: Stock
Rear Swaybar: May be stock or could be a little thicker.
Bracing: None at the moment.
Plans/Settings: running 3.2 neg camber, 0 toe, 3 degrees castor
plans r to convert front to coilovers and 7kg springs with bilstein inserts and RCA's
rear i plan to run bilsteins and get a 20mm swaybar, maybe raise it up a lil too
Pro's: seems to be alright at the moment, cant wait to bilstein it up!
Con's:lil sloppy
Mine: Build engine, get an alignment then start playing with it all after I see how it handles, buy a front strut brace and make a rear one.
Extra Comments: Still has fc brakes, custom steering arms and lock spacer for epic lock but now the lock is held back by tyre scrub after changing the LCA's. New urethane bushes throughout.
