Page 14 of 16 FirstFirst ... 4 5 6 7 8 9 10 11 12 13 14 15 16 LastLast
Results 131 to 140 of 152
Thread: Your Suspension Setup
  1. #131
    Veteran slydar's Avatar
    Dimitri
    yeah. with those spring rates it works pretty good. a bigger rear bar to go with it would make it better. but im changing spring rates so..
    78's
  2. #132
    Mar 2010
    Drew
    Lilydale
    ditch the heros for steerers, dip in your pockets and run something, decent, a federal 595 is better and only around 30 per tyre more, or adrenalines, or if your running 15s and go all out with r1rs haha
    but seriously, there is no way you car shouldnt turn em, what trye pressures do you run, theres a big difference from 32-36 psi
  3. #133
    Hair model Jacobxxx's Avatar
    Jacob
    Sunshine Coast
    Can't get 595 in 14's, hz1's are from the same factory and extremely similar tyre
  4. #134
    Mar 2010
    Drew
    Lilydale
    yeah, you can, in about 4 different sizes from 185/55 - 205/60
    ive recommended them for a few cars lately, and any hero ive seen, has been slippery as shit, i dont see this being different
  5. #135
    Veteran AJPS's Avatar
    Lonsdale
    yeah i agree with this - ive not seen the ones that D has tho
    Just put a stock ARB in it, and go faster
    a small port is never going to bag the tyres, should be good tho
  6. #136
    Jacob
    Sunshine Coast
    I tried for ages to get some, federal dealer kept telling me they don't stock them anymore in 14's so i opted for the HZ1's, can't complain about them though. Were awesome in super heavy rain at QR and then awesome in the dry.
  7. #137
    Mar 2010
    Drew
    Lilydale
    they are definetly avalable in melbourne
  8. #138
    Jacob
    Sunshine Coast
    Stupid QLD/Northern NSW, Clay was telling me he can get them too. Ah well.
  9. #139
    Veteran timbo's Avatar
    Tim?
    Wild West
    Car: AE86
    Car use: non-drift/daily
    Front Struts: AE86, TRD coilover
    Spring Rate/ Free Height: ~8kg/mm, 200mm
    Inserts: Tokico HTS 102F
    LCA's: XT130, RA40 rack ends
    RCA's: T3 33mm
    Strut Tops: Cusco normal caster
    Front Sway Bar: 21mm Stock, urethane bushes
    Castor Arms: Stock
    Rear Springs: TRD ~6kg/mm
    Rear Shocks: TRD Blue 8way
    Panhard Rod: Whiteline
    4 Link: Whiteline solid lowers, adjustable uppers, urethane bushes
    Tractions brackets: T3
    Rear sway bar: 13mm Stock
    Bracing: Whiteline strut brace, Cusco half cage
    Pro's: Plenty of grip, very direct
    Con's: Little stiff at times
    Extra Comments: Did previously run 24mm front and 18mm rear Whiteline ARB's and the car handles much better without them. Rear could probably go a little bigger, maybe ~15mm.
  10. #140
    West
    Car: AE71 1983 Slanty
    Car use (e.g grip/drift): Daily/Grip.
    Front Struts:AE86 Coilover cut to suit ae92/st185-205/short stroke 86 shocks. Suits body length of 332mm with no spacer.
    Spring Rate/ Free Height:approx 6kg rate possibly eibach.
    Inserts (brand/model):Koni Sport ST185 adjustables (yellow)
    LCA's:XT130 with original Toyota balljoints.
    RCA's (size if you have them): 30mm Techno Toy Tuning
    Strut Tops: Tein Caster added for ae86 which suits ke70/ae71 perfectly.
    Front Sway Bar: Stock.
    Castor Armstock.
    Rear Springs: Superlow Kings fairly soft.
    Rear Shocks: Koni Sport AE86 adjustables (yellow)
    Panhard Rod: Whiteline Adjustables
    4 Linktock lowers with Nolathane Bushes. Adjustable upper whitelines with the urethane bushes.
    Bracing: Strut brace, and a towbar with the tongue removed to stiffen the rear end and protect the fuel tank from rear enders. Saved my life once already.
    Steering Stuff: Rebuilt ae71 rack and pinion with Quaife parts (2.5 lock to lock). AE71 Rack ends, RA40/KE30/XT130 tie rod ends and link tubes. STD ae86 steering arms.
    Pro's: Good all rounder. Nimble steering but a little sensitive over 160klm/hr, but still quite safe.
    Con's: Set at highest possible ride height and still quite low. Still above 100mm though.
    Extra Comments:
  1. (SA) *E7*/86 BC/AJPS Rear Suspension setup/ 2871r turbo setup
    By sleeper_13 in forum Car Parts For Sale
    Last Post: 25th July 2012, 01:06 AM
  2. Need Help With Suspension Setup
    By ArbPotatoes in forum Technical - Questions
    Last Post: 30th June 2009, 10:51 PM
  3. ke70 suspension setup
    By biggo in forum Car Parts For Sale
    Last Post: 9th January 2008, 12:16 PM
  4. WTB::: suspension setup
    By winslow in forum Cars or Parts Wanted
    Last Post: 16th August 2007, 04:53 PM
  5. suspension setup
    By AE86_4life in forum Technical - Questions
    Last Post: 1st November 2006, 08:43 PM
