Page 15 of 16 FirstFirst ... 5 6 7 8 9 10 11 12 13 14 15 16 LastLast
Results 141 to 150 of 152
Thread: Your Suspension Setup
  1. #141
    Veteran anastasios's Avatar
    Taz
    Earlwood
    Can you tell me more about your strut tops? what is the part number?
  2. #142
    Josh
    Gunningbland
    Car: Scorpion
    Car use (e.g grip/drift): Street
    Front Struts: Standard
    Spring Rate/ Free Height: Cut HD Falcons (5kg?), 240mm
    Inserts (brand/model): Monroe Sensatrac (VB Commodore)
    LCA's: Stock, 345mm
    RCA's (size if you have them): None
    Strut Tops: Standard, spun 180deg
    Front Sway Bar: Starion 21mm
    Castor Arms: Stock
    Bushings: NOS stock/Nolathane
    Knuckles: Stock
    Rear Springs: Lovells low (4kg?), 250mm
    Rear Shocks: Monroe GT Gas (TP Magna wagon)
    Panhard Rod: Stock
    4 Link: Stock
    Rear Sway Bar: None
    Bracing: None
    Pro's: Comfy, looks ok, decent grip
    Con's: Needs better/short stroke shocks, 9/7kg springs, bracing F+R and an adjustable panhard
    Extra Comments: Not sure how helpful/relevant this is, but hey...
    Car's not registered. Has open rear end, so slides like shit unless it's on gravel/wet. 4.6 rear end. Shopping cart-spec Goodyear/Sime 185/65's.
  3. #143
    Taz
    Earlwood
    soooo bought some jdm standard struts the other week to pull apart and get some trd gear for, as i pulled off the dust cover noticed a four way adjustable shock!! i nearly did a back flip
    turns out they are Bridgestone Potenza Gymkhanas made by KYB, on the shock it says SUS00125 and MD29 KYB
    body length of 402mm, not sure where to measure extended length from
  4. #144
    Veteran shift_rook's Avatar
    SE Burbs
    Shoulder of the chrome shaft to the base
  5. #145
    Sep 2011
    Shannon
    South
    Car:ke70
    Car use (e.g grip/drift): drift
    Front Struts: s13 g4 coilovers
    Spring Rate/ Free Height: 7kg and slammed
    LCA's: r31
    Strut Tops: adjustable g4
    Front Sway Bar: not running sway bar
    Castor Arms: adjustable r31
    knuckles: Custom
    Rear Springs: 7kg
    Rear Shocks: turbo gas
    Panhard Rod: adjustable r31
    4 Link:
    Bracing: rear weld in supports
    Pro's: car doesnt move at all, stiffer then a horney teenagers d**k, front end handles awsome, plenty of grip front and rear
    Con's: none, perfect setup for wat i need
    Extra Comments:
    standard lock is rather small with s13 front for an unknown reason, but with the addition of knuckles and rack spacers i have about 55-65 degress of lock
  6. #146
    Oct 2011
    Tevin
    nsw
    Blacktown
    Where exactly have you put the bracing?
  7. #147
    Mick
    Penrith
    Car: ST141 Wagon
    Car use (e.g grip/drift): daily/grip
    Front Struts: Stock
    Spring Rate/ Free Height: AJPS 180mm 7kg
    Inserts (brand/model): KYB Excel G SW20 inserts
    LCA's: XT130 w/ Nolathane bushes
    Rear Springs: AJPS 6kg 200mm
    Rear Shocks: Boge Turbo AE86
    Pro's: Great for spirited driving
    Con's: Rear rates are too high for my liking, will be changing to 4kg. also needs a strut brace.
    Extra Comments:
    14x7 MA61's, Yokohama C drive 185/60
    Castor: +3 deg
    Camber:-1 deg
    Toe out: 1mm total
  8. #148
    Veteran Rice86's Avatar
    Richard
    Liverpool
    Car: AE86
    Car use (e.g grip/drift): all of it
    Front Struts: BC coilovers
    Spring Rate/ Free Height: BC coilovers 8kg
    Inserts (brand/model):BC coilovers
    LCA's: stock AE86
    RCA: 40mm/50mm i think
    Swaybars F/R: standard front and standard rear
    Castor Arms: stock AE86
    knuckles: ae86 power steering nuckles
    extra: lock spacer, T3 complete 4 links and T3 pan hard rod
    Rear Springs: BC coilovers (shock and springs) 6kg
    Rear Shocks:BC coilovers (shock and springs)
    Extra Comments:
    Yokohama S drives 195/50/15
    Castor: +3.5
    Camber: -2
    Toe out: 1mm on both sides
    Pro's: so easy to drive with this setup for daily, track, touge, and drifting in the wet, have not tried drifting in the dry with this so i wouldn't know, very neutral and forgiving
    Con's: +4 Castor would be better, maybe -2.5 camber when on track/drifting..needs an updated wheel alignment after installing T3 rear end suspension parts
    dose
  9. #149
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    Car: ke70
    Car use (e.g grip/drift): daily, general thrashing
    Front Struts: cut 86
    Spring Rate/ Free Height: Elbach 8kg
    Inserts (brand/model): TRD blue (tokito's)
    LCA's: Sigma
    RCA: Nup
    Swaybars F/R: No Front, Standard Rear
    Castor Arms: Just crap Rose joint ones
    knuckles: ae86 knuckles Cut and shut
    extra: lock spacer, Commo Panhard cut and adjustable
    Rear Springs: ajps 210mm 1 1/2 coil cut off 6kg
    Rear Shocks: Peddars GSR's keep springs captive and stiff
    Extra Comments:
    Castor: +4.5 ish
    Camber: -4
    Toe out: 2.5mm on both sides
    Extremly Over steery, power out of corner in the dry(3rd-4th) you feel the rear wanting to step, in the wet its pretty loose, steering feels like a gokart, even with old continental's (comforts) on the front sticks like shit to a blanket
  10. #150
    Senior Member KE20's Avatar
    Feb 2010
    Haydn
    South
    Car: KE20
    Car use daily/hills
    Front Struts:KE20
    Spring Rate/ Free Height: 5kg
    Inserts (brand/model): Bilstein
    LCA's: Stock
    RCA's (size if you have them): T3 30ish mm
    Strut Tops: Cusco - 1.3 deg
    Front Sway Bar: Stock super pro bushes
    Castor Arms: Stock +3
    Rear Springs: Stock leaf,2nd leaf flipped
    Rear Shocks: TRD green 2nd click from softest
    Panhard Rod:None
    4 Link:None
    Bracing: Cusco front (not fitted atm no stock filter clearance) custom rear being made
    Pro's: handles well for what it is,fun to drive
    Con's:little stiff in the front,needs reset leaves in the rear
    Extra Comments:Needs more grip (tyres) advan AD05/06 in the way for the front
  1. (SA) *E7*/86 BC/AJPS Rear Suspension setup/ 2871r turbo setup
    By sleeper_13 in forum Car Parts For Sale
    Last Post: 25th July 2012, 01:06 AM
  2. Need Help With Suspension Setup
    By ArbPotatoes in forum Technical - Questions
    Last Post: 30th June 2009, 10:51 PM
  3. ke70 suspension setup
    By biggo in forum Car Parts For Sale
    Last Post: 9th January 2008, 12:16 PM
  4. WTB::: suspension setup
    By winslow in forum Cars or Parts Wanted
    Last Post: 16th August 2007, 04:53 PM
  5. suspension setup
    By AE86_4life in forum Technical - Questions
    Last Post: 1st November 2006, 08:43 PM
