Page 16 of 16 FirstFirst ... 6 7 8 9 10 11 12 13 14 15 16
Results 151 to 152 of 152
Thread: Your Suspension Setup
  1. #151
    Senior Member Flush-on-15s's Avatar
    May 2013
    dylan
    Echuca
    Car: AE71
    Car use (e.g grip/drift): Grip
    Front Struts: AE86 Coilovers
    Spring Rate/ Free Height: 6kg 200mm
    Inserts (brand/model): KYB excel short stroke
    LCA's: ke30 (same as xt130)
    RCA's (size if you have them): 40mm
    Strut Tops: cusco
    Rear Springs: 5kg 180mm on AJPS adjustable spring perch's
    Rear Shocks: monroe vn wagon short stroke
    Panhard Rod: AJPS Adjustable
    Pro's: Haven't even driven the car yet... but should be good adjustable is amazing though very happy with the quality
    Con's: very expensive and time consuming to put all this together
    Have a Look at my ae71 streeter build thread!
    http://www.ae86drivingclub.com.au/fo...s-Clean-Spirit
    Quote Originally Posted by timbo View Post
    This is like reading the Women's Weekly.
  2. #152
    Junior Member mexr69's Avatar
    Sep 2013
    Cee
    yarrglen
    Car: st141 corona
    Car use drift
    Front Struts: s13 coilovers
    Spring Rate/ Free Height: 8kg
    Inserts (brand/model): china cheapies
    LCA's: r31 lca
    RCA's (size if you have them): n/a
    Strut Tops: Cusco - 1deg
    Front Sway Bar: n/a
    Castor Arms: unsure.
    Rear Springs: ea falcon extra hd
    Rear Shocks: commodore wagon extra hd
    Panhard Rod:None
    4 Link:None
    Bracing: stoock nice n stiff
    Pro's: handles well for what it is,fun to drive
    Con's: front doesn't correct slight bump streets
    apart from that it feels nice.
  1. (SA) *E7*/86 BC/AJPS Rear Suspension setup/ 2871r turbo setup
    By sleeper_13 in forum Car Parts For Sale
    Last Post: 25th July 2012, 01:06 AM
  2. Need Help With Suspension Setup
    By ArbPotatoes in forum Technical - Questions
    Last Post: 30th June 2009, 10:51 PM
  3. ke70 suspension setup
    By biggo in forum Car Parts For Sale
    Last Post: 9th January 2008, 12:16 PM
  4. WTB::: suspension setup
    By winslow in forum Cars or Parts Wanted
    Last Post: 16th August 2007, 04:53 PM
  5. suspension setup
    By AE86_4life in forum Technical - Questions
    Last Post: 1st November 2006, 08:43 PM
