disregard that. i got it. thanks!
inners and outters? or RUNNIT with a sleeve like numbers 4 and 5?
Anyone got a known measurement for an XT14X corona? i tried to measure compared to an XT130 but i only had a ziptie to measure with. Im thinking the MX62 arms will go well on a corona somehow...
st141/rt142 are the same length as kesev ae71 sprinter... like, 300mm i think. mx62 will be ridiculously long but they are how-ever a good thing to use when doing s13 front end. i used silvia recently and they are shorter so a bit more conservative but more drilling to make it fit and less castor due to mounting points.
is that a big crack running down your caliper?
but man those weld on kits look the shiz!
I dont see any crack, a casting mark yes
ive read the hole artical but i have stock suspension just upgraded springs and the car is lowered, from what i can understand i can put xt130 lca in my ae86 and use all my standard parts that are in my ae86 (i have no power steering). i dont have camber adjusters either, and what i want to know is what camber will the xt130 lcas give my car if i fit them only???
-1 to -1.5 degrees
Yeah, dont bother unless you are going to a full MX83 front end. I have a full MX83 front end on my Supra, and its quite nice, but the balljoint is unique to the MX83 and so you need to use the matching steering arms, and then the matching struts as they are odd spacing too... etc.
So if i wanted to cut my LCAs and make them longer, about 10mm would give me an extra degree or so? and also, also would like adjustable LCA's so if any1 has a build/howto thread on what you need to do that would be awesome
sorry if its been in this thread before, i just quickly read over it.
