Results 1 to 10 of 11
Thread: FB25 engine to power FT86
    Senior Member 4.5AG's Avatar
    Vener
    NT
    Lyons
    Default FB25 engine to power FT86
    In non-turbocharged models, a new engine (designated FB25) sits under the hood. It has the first completely new design from Subaru in 20 years.
    Subaru had a number of goals for FB25, including improved fuel economy and higher performance, especially at low engine speeds (low-end torque). Major differences between the FB25 and the EJ25 (which remains the engine of choice for turbocharged Forester models) include:
    Smaller bore and longer stroke
    Slightly higher displacement
    Chain-driven double-overhead camshafts instead of belt-driven single-overhead camshafts
    Compared with the previous non-turbocharged EJ25 engine, the FB25 produces:
    Same horsepower, but at lower rpm
    Slightly higher torque at lower rpm
    Improved fuel economy
    Does that mean that the"F" on FT 86 stands for FB25?
    Gunner
    it'll have direct injection
    Gunner
    I was wrong, it looks to be a 4 banger version of the EZ30, which isnt a bad thing.
    Just hope they keep some sort of EJ variant in the years to come, otherwise no easy mods for anyone for long time.
    Senior Member Moebius's Avatar
    Christian
    Why the switch to a timing chain instead of belt? What's the advantage there?
    Will
    they don't need to be replaced and make a cool rattling noise. i'd imagine subaru owners would be quite happy to never have to replace a timing belt on those stupid VW motors.
    Aaron
    In the Mountains
    great, so not only is it a epic cross bread on a old chassis, it now has a lovely truck motor! it just keeps getting better and better!
    Vener
    NT
    Lyons
    EZ30 timing chained boxer engines are one of the smoothest and reliable engines.
    Gunner
    and sound absolutley porn
    heres one i prepared earlier
    I put this together while I was at Pulse Racing, would have to be one of my all time favourite subaru's that I have worked on, beautiful seamless power, from idle to redline. Ended up with near on 300kw on 12psi with standard internals.
    Vener
    NT
    Lyons
    Sounds like a 911...
    Dave
    that liberty is wicked.
    - Blaise Pascal
  1. Do You Have an FT86? Because I do.
    By Gunner in forum AE86 Owners Forums
    Last Post: 17th August 2013, 05:26 PM
  2. Replies: 10
    Last Post: 22nd December 2012, 03:21 AM
  3. What the FT86 should look more like...
  4. ft86 in FHM
  5. (KE70: 4K-C --> 4AGE 16V Big Port) 12v Engine Power Wiring Q
    By bally in forum Technical - Questions
    Last Post: 16th February 2011, 04:37 PM
