I've followed this guide to put a RWD JDM Kouki 4AGE into a ADM AE86...
I get a good strong spark, but it doesn't start.
* ECU has constant power and IGN power, tested
* Coil has IGN power, tested
* Have fuel pressure (so COR is working)
I used the same relay that powers the coil to power the yellow injector wire, that should be ok?
The only thing I can think now I've had time to mellow is the Starter wire...
I plugged the original ADM starter wire in (that comes from the round black plug on the firewall)
I did notice there was another starter wire in with the kouki engine harness tho... should that one get plugged in also/instead? cos the ECU does require a starter signal, doesn't it?
