Page 3 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 21 to 30 of 85
Thread: HOW TO: 4AGE into ADM AE86/AE71 Wiring guide
  1. #21
    EFI relay is the one in the middle... Same relay as the main and can be found in ae82 / ae92's etc. If you take the plugs off the numbers are printed on the pins.
    You'll need to add the high amp input + output wire to the fuse box. One i'm pretty sure is on the orange connector on the side and the other is the far right plug on the top. From memory the output is on the side and the input on the top.
    If you aren't in a rush i'll be doing another one next wekend so i'll let you know.
  2. #22
    Veteran anastasios's Avatar
    Taz
    Earlwood
    Guys,
    What are the wires going into this plug on a JDM AE86 4AGE
  3. #23
    Going by colours...
    Red Black / Reverse lights
    Yellow Green / temp gauge
    Yellow black / oil pressure
    Black white / starter signal
    black orange / ign
    black / tacho?
  4. #24
    Taz
    Earlwood
    What about the:
    yellow
    black orange
    black
    black white
  5. #25
    Veteran Nikkojoe's Avatar
    Tom
    Yellow is injector power BF. Alternator wiring on a jdm ae86 loom is seperate to the engine loom (found on the engine bay harness).
    So corrected it is:
    Red Black (or red blue) / Reverse lights
    Yellow / injector power (conect this to 12v switched on ignition)
    black orange / ign (connect this to 12v switched on ignition OR connect as discribed in the first part of the guide)
    black with brown dots / tacho (old tacho wire will be found near the old coil, same colour (or just a plain black wire)).
  6. #26
    Dec 2011
    Kerry
    Warradale
    quick one...thanks for the guide, will come in handy thats for sure...
    one question though, how do i bypass the neutral start switch in an auto shell?
  7. #27
    Taz
    Earlwood
    Any idea what the black wire is in this plug?
  8. #28
    Tom
    Most likely tacho, brown dots are usually hard to see. Check with a multimeter that it goes back to the negative side of the coil.
  9. #29
    Dec 2011
    Kerry
    Warradale
    ok...i have a quick one for you...
    i have two wires coming out of my loom right near my injectors...
    the colours are:
    red w/ blue trace
    red w/ black trace
    are they just the reverse lights?
  10. #30
    What loom do you have?
    But yes, they are usually reverse lights.
  1. 4age in ADM 86 won't start. Wiring?
    By genkin in forum Technical - Questions
    Last Post: 31st December 2012, 09:27 AM
  2. plug and play wiring loom - 4age to ADM ae86
    By StuC in forum General Topics (No Technical Questions)
    Last Post: 13th April 2011, 09:52 AM
  3. 4age bigport wiring in to adm ae86 need help asap
    By fat_ke in forum Technical - Questions
    Last Post: 18th September 2010, 07:52 AM
  4. wiring up 4age into adm 86
    By driftnick13 in forum Technical - Questions
    Last Post: 2nd January 2010, 05:00 PM
  5. Trev's Guide To Repairing 4age Dizzy Wiring
    By Trev084 in forum Technical - Articles
    Last Post: 25th August 2008, 09:04 PM
