Page 5 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 41 to 50 of 85
Thread: HOW TO: 4AGE into ADM AE86/AE71 Wiring guide
  1. #41
    Veteran slide86's Avatar
    Huw
    Hills
    wire direct 12v power to the yellow wire with a relay that comes on when IGN on.......
  2. #42
    Member _sawyer_'s Avatar
    Feb 2010
    Paul
    West melbourne
    Hey does anyone know what color the engine light wire is for the dash and the best place to tap into it on a AE86?
    Also running the taco on this car from a 20v ecu, can u just run the output from the ecu into the original coil harness?
  3. #43
    Dylan
    South Australia
    Ingle farm
    Got a 16v smallport and I am having injector pulse issues
    i have good spark and the ecu is ground as well as all the engine earths
    and such yet still no pulse. I have 12v at the black w orange trace
    coming to the injectors but I get no pulse when I tested all 4 with a noid
    light.
    what could be causing the lack of signal for the pulse to say its doing my head
    would be a massive understatement.
    Any help would be much appreciated.
    Also is powering the coil ecu and injectors off the one relay maybe a
    maxing the relay out?
    Let me know dudes
  4. #44
    They are both powered off the main relay in the fwd format so no, it isn't a problem. You don't need to ground the ecu as it is done thru the loom thru the main earth bunch.
    Any ecu codes?
  5. #45
    Jul 2009
    Daniel
    Morisset
    Hey guys im currently trying to install a jdm dash loom into my adm 86, I have most things pluged in but I have noticed the jdm loom hasnt got the plug for the wiper motor and the section that runs across the top of the firewall that has the reverse lights, starter motor signal wire, I need urgent help with this as I need to have the car running asap for rego.
  6. #46
    Do you have a squarish looking yellow plug inside the cabin? Possibly you have a zenki loom... Post up a pic of what you have and we can go from there..
    Reverse lights are traditionally red / black and red / blue and will be on the yellow plug.
  7. #47
    Jul 2009
    Daniel
    Morisset
    Yea from what I was told it is a zenki loom, I can see the yellow plug on the loom. All the pins are the same size it looks like its the ecu plug its not the one pictured on page 1 of this thread, im guessing thats the one I need that people mistake for the ecu plug? I cant upload pics as im only on my phone but I can text them to you...
  8. #48
    So you replaced the loom in the cabin with the zenki one.... and now have the engine harness running across the firewall from the passenger side to the middle and nothing to mate up with?
    The ones across are the firewall are for gauges , reverse lights and starter so they would be easy to pull into the car via the wiper hole , but you will have to lenthen them.
  9. #49
    Jul 2009
    Daniel
    Morisset
    I have no problem lengthening them, I need to know where they hook upto on the zenk loom, and I need to find the wiper motor plugin.
    Im starting to strip back the adm loom to follow them.
  10. #50
    Pretty certain the colours match up perfectly on the zenki plug as they do on the adm in that
    black / white - starter
    yellow / black - oil pressure
    yellow / green - temp gauge
    Red / black - rev lights
    Red / Blue - rev lights.
    They'll all be there, might be easiest to get an 8 pin narva connector set and join them that way...
  1. 4age in ADM 86 won't start. Wiring?
    By genkin in forum Technical - Questions
    Last Post: 31st December 2012, 09:27 AM
  2. plug and play wiring loom - 4age to ADM ae86
    By StuC in forum General Topics (No Technical Questions)
    Last Post: 13th April 2011, 09:52 AM
  3. 4age bigport wiring in to adm ae86 need help asap
    By fat_ke in forum Technical - Questions
    Last Post: 18th September 2010, 07:52 AM
  4. wiring up 4age into adm 86
    By driftnick13 in forum Technical - Questions
    Last Post: 2nd January 2010, 05:00 PM
  5. Trev's Guide To Repairing 4age Dizzy Wiring
    By Trev084 in forum Technical - Articles
    Last Post: 25th August 2008, 09:04 PM
