Just a quick question, is it easier to wire in an aftermarket ecu and loom oppose to the standard 4age ones?
What side of the car will these be on when the loom is fitted, drivers side or passenger side, also what about the wiper motor wires?
Harder...
As after market ecu you have allot mroe wires to deal with for all the sensors etc. Generically with factory ecu's you don't need to touch any of the sensor wiring.
ok starting to peace together my loom that cam with the 16v ae82 bigport, Im having trouble with a couple of things and just want to check, i have the middle plug on my ecu but not the other two, i understand that one is a body loom so does that mean i have to source it from a ae82? and as for the other one i have 7 wires with the tips that look like they should plug into a ecu plug there all black brown or brown and white, unsure why this loom came with no second ecu plug so my question is any idea were i can source a plug? and does any one have an ae82 body plug if thats the one i need, car currently still has 4ac loom in it ae86
post up a pic of what you have, might be easier to get a new loom... ecu plugs can be found at the wreckers sv21 camry has the same one...
i figured out the 7 pins, thanks to the pin out diagram, now my only issue is the injector loom has been cut and i cant figure out fwere it conects as the other loom seems to be complete and un cut i will post picks up later, it would be good to look at someones ae86 all ready wired up if someone has a bigport around melbourne area?,
Hey, never seen one before so i made one up, it the pinout for the Relay/Fuse box located in the engine bay of Ae71 (not sure, but its probly the same pinout for ke70s also)
AE71 4A-GE | Quad Lights |Coilovers F8kg R6kg | W55 | Kouki T Series W Unknown LSD
KE10 | 4K | K50 |
hey does anyone have a link with the ecu pinout that lists what the abreviations stand for, its a ae82 4age im after , i know some of the abreviations but not others, ? i could list the ones i dont know but there are a few
You mean this?
Adam, thanks so much for that. I was looking that fuse panel wondering whether I put some of the wires in the right places.
thats exactly what i ment cheers
