Cheers mate, progress may be a bit slow as I start fly in fly out again next week.
fucking pro job man will follow this
Been working away so progress has slowed on the KE. Have done a few things,
Uploaded with Had to make up a spacer/bush for the rear coilovers to fit the mounts properly.
Uploaded with
Fitted up the cooler and alloy rad.
Uploaded with
Made up an alloy dash panel, still need to fit the rest of the guages
Uploaded with
Pretty much just wiring and tailshaft left now. I've got a nistune ecu but still not sure bout it .
been waiting on an update
looks like a promising build great work
is that cooler piping one of those ebay package deals
or did u custom make it urself
Cheers mate, nah its custom piping. Some of it came with the motor I bought and just made the rest to suit. Wanted to flip the cooler and run shorter pipework but it hit the headlights etc
wat radiatior is that you are running
Not too sure what brand mate, I bought it off the local silvia forums.
tuff as any updates?
Cheers mate, yeah little bit more done. Finished mounting the rad and cooler, fitted rear sway bar and pumped the front guards out so I could drop it to where it should be . Also got most of the wiring sorted so shouldn't be too far off now! Can't wait to fang it.
Uploaded with
Uploaded with
Uploaded with
Uploaded with
Uploaded with
did you paint this yourself? And is it only inside, or is the outside fresh paint too>?
