Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
Thread: nz trueno build
  1. #11
    Moderator Sam-Q's Avatar
    Endeavour Hills
    that doesn't sound right at all. It's not like a 20V , because as far as I understand the cam pulleys are fully variable. So even with the wildest race cams you could tune them more, for example retard the exhaust cam at lower revs to stop the mixture blowing out the exhaust resulting in a higher dynamic compression ratio. So it should be impossible to have cams that are not VVT compatiable, well unless they go very close to the pistons as it is.
  2. #12
    Glenn ke_70's Avatar
    Clay
    Barossa!
    unsure. make a tech question?
  3. #13
    E-Famous (Remeber your roots)
    I thought it was pretty cool..
    Starting reading specs... D2 suspension and china oil cooler with 200m lines? wat
  1. Toyota motorsports NZ - Toyota 86 Build
    Last Post: 13th October 2012, 01:21 PM
  2. [FS] Two Trueno Build Kit Models.
    By Beau in forum Other Items for Sale
    Last Post: 8th June 2011, 03:07 AM
  3. NZ trd N2 ae86 build . more then just a replica
    By redsprinter in forum Toyotas in the Media
    Last Post: 14th January 2010, 06:07 PM
  4. trueno build up
    By 350hp4agte in forum AE86 Owners Forums
    Last Post: 14th November 2007, 10:07 PM
  5. Cool Ke70 build up from NZ
    By intense in forum Toyotas in the Media
    Last Post: 6th July 2007, 05:52 PM
