Page 11 of 18 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 LastLast
Results 101 to 110 of 174
Thread: Building a 7age.
  1. #101
    gawler area.
    ok sweet cheers fellas
    hachi roku
  2. #102
    Ok
    Seamus
    Milton
    I made 160rwhp
    I use my own rods - i only have a couple of sets left
    If you're sticking to a low rev-limit like robo did (7200rpm), then stock 7A rods are fine. That said, by the time he bought new rod bolts and resized the rods he was halfway to the cost of forged rods. All budget dependant i guess
    ^ Clicky clicky!
  3. #103
    Senior Member Adsie's Avatar
    Adam
    Birkdale
    I used stock rods in mine with a 7500rpm limit goes fine but isn't daily driven. I also brought new rod bolts, didn't resize the rods.
  4. #104
    Aug 2010
    Sutho Shire
    is it true you use a ke70 throttle cable and a 4 ac fly wheel?or can i use the flywheel from my bigport currently in car?car is a 86
  5. #105
    Apr 2010
    Mike
    nah you cant use 4a flywheel as they are 8 bolt where 7a is 6 bolt
  6. #106
    Aug 2010
    Sutho Shire
    so ide need the 4afe flywheel?or is there something else everyone uses
  7. #107
    4ac is actually a 6 bolt flywheel...
  8. #108
    Aug 2010
    Sutho Shire
    so i should grab a 4 ac flywheel,or is there a beter option to go with?can the 4 ac be machined?
  9. #109
    Aug 2010
    Adrian
    South
    While this thread is seeing some action. Can I used a bigport 4age clutch on the 7afe flywheel? My 4age clutch is almost new and dont want it to goto waste
  10. #110
    Ok
    Seamus
    Milton
    Depends on your clutch size.
    If you were running a smallport flywheel/clutch (212mm), then it will bolt straight up to a 7AFE flywheel.
    If you were running a bigport AE82/AE86 flywheel/clutch (200mm), then you need a 4AC flywheel.
    ^ Clicky clicky!
  1. Replies: 22
    Last Post: 5th March 2012, 10:33 AM
  2. building need parts..
    By josh.. in forum Cars or Parts Wanted
    Last Post: 31st March 2011, 09:55 PM
  3. Building a cage
    By driftke70 in forum Technical - Questions
    Last Post: 27th January 2007, 04:16 PM
  4. Building 4age
    By works510 in forum Technical - Questions
    Last Post: 6th March 2006, 05:14 PM
