Page 15 of 18 FirstFirst ... 5 6 7 8 9 10 11 12 13 14 15 16 17 18 LastLast
Results 141 to 150 of 174
Thread: Building a 7age.
  1. #141
    Elite rthy's Avatar
    Leo
    Tulla
    Am i allowed to do a dodgy and used a press pin with a smallport piston?
    edit:
    4AGE 100kw/Smallport Pistons use 20mm floating pin
    7AFE Pistons use 20mm press pin
  2. #142
    When i did my 7a with 20v pistons, it was pressed in... Was advised by the machiner not to put a circlip on it...
  3. #143
    Elite rthy's Avatar
    Leo
    Tulla
    did you get the piston piston machined to fit the pressed gudgeon pin?
  4. #144
    I paid the machiner $30 to do them for me, not sure if machining was required or not....
  5. #145
    Elite rthy's Avatar
    Leo
    Tulla
    Thanks, did you have any issues with it?
    just need to sort out the pistons then will blow tyres..... UP
  6. #146
    Senior Member Adsie's Avatar
    Adam
    Birkdale
    Mine uses stock 7AFE rods and 20V pistons. The pins are pressed into the rod and the piston can move. Pistons do not need to be modified.
  7. #147
    Elite rthy's Avatar
    Leo
    Tulla
    i wonder if the smallport 16v are different to 20v ones?
    But i have seen 16v pistons used on 20v blocks - then again donno if any mods are done.
  8. #148
    Veteran willa's Avatar
    Will
    Northern 'burbs
    Have any of you guys used ca18 pistons in your 7a builds? I recently heard of someone who did, not sure on what c.r it ended up with though
    SuperFunHappySliders
    SR's are ghey.
  9. #149
    20v pistons can easily be interchanged with 16v... so my pistons didn't need modifying...
  10. #150
    Without crunching numbers.. Something Sam Q might do if you ask him too...
    Ca18 pistons are often used in smallport 16v 4.5ag builds...ie 83mm bore, offset ground crank...often resulting in higher compression that standard ae92 pistons...
    From memory when robbo/seamus built his 7ag 16v they used smallport pistons and resulted in a high comp motor with little ability to wind timing into it (stock ecu)
    using ca18 pistons would result in high compression again (in theory)...a 83mm bore with the less than ideal rod stroke ratio of the 7a could be asking too much...
    I'm definitely no engine building expert, so don't take it as gospel...just selection of information I've retained over the years and knowledge from having my own motor built...
  1. Replies: 22
    Last Post: 5th March 2012, 10:33 AM
  2. building need parts..
    By josh.. in forum Cars or Parts Wanted
    Last Post: 31st March 2011, 09:55 PM
  3. Building a cage
    By driftke70 in forum Technical - Questions
    Last Post: 27th January 2007, 04:16 PM
  4. Building 4age
    By works510 in forum Technical - Questions
    Last Post: 6th March 2006, 05:14 PM
