Page 18 of 18 FirstFirst ... 8 9 10 11 12 13 14 15 16 17 18
Results 171 to 174 of 174
Thread: Building a 7age.
  1. #171
    Nov 2015
    kenshin
    cavite
    silang
    philippines
    hi, permission to post
    i used/still using in my 7a-ge:
    flywheel from 5af, lightened and balanced to 6kg
    Clutch from 4af
    stock pistons of Honda Sir (High Compression)
    4ag bigport head minus tvis (ported and polished)
    red top stock fuel injector (green)
    red top stock ecu
    fabricated phantom grip LSD
    timing belt from Nissan (part# 1177BS25 13028-54AO1 however, you need to trim about 5mm from one edge as original is wider)
    Jasmag 4-2-1 exhaust
    finally stock cams of blue top.
    FRANKENMOTOR as they say.
  2. #172
    Nov 2015
    kenshin
    cavite
    silang
    philippines
    i used the 5af for my 7ag. lightened and balanced. well, that's what i paid for.
  3. #173
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    I've read through the whole thread and done a fair bit of searching, I know you use the Porsche 944 timing belt on a 7A-GE 16v with the 7A-FE oil pump however I can't seem to find which timing belt to use with the 16v oil pump? I know they're 116 teeth instead of 117 like the 944, but can't locate a part number.
    Any one got some info for me?
  4. #174
    Senior Member Jip86's Avatar
    Lindsay
    Mackay
    Gates T018.
  1. Replies: 22
    Last Post: 5th March 2012, 10:33 AM
  2. building need parts..
    By josh.. in forum Cars or Parts Wanted
    Last Post: 31st March 2011, 09:55 PM
  3. Building a cage
    By driftke70 in forum Technical - Questions
    Last Post: 27th January 2007, 04:16 PM
  4. Building 4age
    By works510 in forum Technical - Questions
    Last Post: 6th March 2006, 05:14 PM
