yeah 7afe is a fwd water pump and doesnt have bypass. but if oyu read the build again you will see that they said to use the rwd water pump. you need to use the rwd pump setup becuase you arent using the fwd head.
remember the fwd water pump goes directly to the head above where the pump is.
