Page 3 of 18 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 ... LastLast
Results 21 to 30 of 174
Thread: Building a 7age.
  1. #21
    Ok
    Seamus
    Milton
    Yeah that compression would be fine. I seem to remember Robo's is up around that number, he just had to run 7 degrees of base timing instead of 10 .. unless you plan on cams.. which would be awesome.
    ^ Clicky clicky!
  2. #22
    E-Famous (Remeber your roots)
    Cams later.
    Want stock ecu. And like 27x cams
    Oversize Toyota pistons fine?
    Worth balancing crank and running lighter harmonic balancer? Like about would like to go 27x cams later. stock ecu..
  3. #23
    Dec 2010
    Cal
    im not 100% but im pretty sure youd just foul plugs and it would run like balls.
  4. #24
    Veteran pen15's Avatar
    Mathew
    Sutho Shire
    only if the limiter gets sat on alot as in drifting but as for racing i think it would be fine and as for the compression i think the more comp the better allows for upgrading the head later and the more comp you have the more efficient the engine will run there is power to be made just in upping the comp lok at smallport compared to bigport 86kw at fly to 100kw at fly cams are the same duration only major difference is the comp, intake ports and ecu
    the dyno pull to 300rwkw
  5. #25
    Veteran Robo86's Avatar
    Rob
    you wont sit on the limiter with a 7a, at least a basic one (stock ecu/cams). there isnt much up top! goes hard through the mid-top though
    http://shirtstuckedin.com/
    my corolla
    Bosman Wholesale Tyres
    3274 5374 - Roy
  6. #26
    Cam's would give it more power up top, so I would be up there more I think.
    People post up their setups!
  7. #27
    block - 7afe
    crank - 7age nitrated
    crank timing gear/sprocket - bazda modified 16v/ae101 20v
    harmonic balancer - ross tuffbond race series (yet to be made, eta july)
    flywheel - toda 4.4kg
    bearings - acl race series
    conrods - belfab racing 7afe
    pistons - custom wiseco (unknown specs, special order by engine builder)
    oil pump - ae101 20v + ae101 20v tensioner
    sump - ae101 sump/ae101 windage tray/tecarts spacer plate + accusump
    oil cooler - greddy thermostatic
    headgasket - stock thickness cometic
    head - ae111 20v (smoothed ports)
    valves - supertech 1mm oversized
    vale springs - supertech heavy duty + ti retainers
    cams - kelford 288/10mm
    cam gears - toda
    timing belt - toda 16v
    intake - ae111 itbs/30mm sptech stacks/nobybooth airbox
    extractors - powercraft 4-1 n2
    cooling system - rschita conversion with genuine 16v waterpump
    radiator - koyo
    ecu - haltech ps1000
    miscellaneous - ARP head/mains/flywheel bolts
    final CR - estimated somewhere between 11.5:1 and 12:1 from memory....been awhile since we worked it out....
    power/torque - unknown
    first attempt starting - ETA 12-18 months lol
    abit of a puzzle/collection of bits and pieces...i honestly dont know what to expect from it...could be 100kw could be 120-130rwkw...quite excited to see how seamus goes with his motor...
  8. #28
    Mathew
    Sutho Shire
    7a block .5mm oversize
    7a crank stock size
    spool con rods
    wiseco pistons comp ratio is 12.37-1
    7a stock brand new Toyota genuine oil pump
    7a sump
    4age 16v stock head gasket Toyota genuine
    4age 16v bigport head ported to the shit
    264 hks cam shafts at 8.1mm lift on intake and 8.35mm lift on exhaust
    toda single valve springs
    fidanza adjustable cam gears
    Porsche timing belt
    t3 quad throttlebody adapters
    ae101 silvertop individual throttle body's
    stock 2nd hand head bolts
    stock 2nd hand main cap bolts
    arp 2000 rod bolts (comes stock with spool)
    and just Toyota genuine seal throughout
    that's my setup there is nothing to over the top for the moment but my new head will flow a few more horses with all the wright mods a 7a will make power up high im thinking of also building a 7a 1zz crank for a nice 2L setup
  9. #29
    ^ what sorta power is that?
  10. #30
    Rob
    everyone knows mine but meh
    Final engine spec.
    7AGE
    -7AFE Bottom end - Honed, 0.5mm Oversize bores.
    -Standard crank (midsized)
    -Kings Main bearings
    -Standard Conrods (Resized + new bolts)
    -ACL Con-rod bearings
    -Hypatech Smallport 4AGE Pistons 0.5mm Oversized. (new)
    -Hastings Piston Rings
    -New standard thickness 4AGE toyota head gasket
    -Standard Bigport 4AGE Head, with some mild porting.
    -New Headbolts
    -4AC Flywheel
    -Apexi Intake
    -TRD copy extractors + 2.25 exhaust.
    -Compression ratio: 11.4:1
    105hp or something, chops my old BP
    my corolla
    3274 5374 - Roy
  1. Replies: 22
    Last Post: 5th March 2012, 10:33 AM
  2. building need parts..
    By josh.. in forum Cars or Parts Wanted
    Last Post: 31st March 2011, 09:55 PM
  3. Building a cage
    By driftke70 in forum Technical - Questions
    Last Post: 27th January 2007, 04:16 PM
  4. Building 4age
    By works510 in forum Technical - Questions
    Last Post: 6th March 2006, 05:14 PM
