Mine is far from a monster..lol..
bang on pat
MY AE86 BUILD
boss doesn't have vvt its been removed but has toda adjustable cam gears
the dyno pull to 300rwkw
That explains it then, one would assume its been simply reset via the cam gears...
Was the initial method i took, but seeing as the oil pump is coming off to replace the ae111 item with a ae101 pump i thought i might aswell change to the modified timing gear also...
MY AE86 BUILD
yeah if you dont use vvt then you dont need a recut keyway, simply play with adjustable cam wheels.
06/07/2011
Worth paying an extra ~$200 for ARP head bolts? Or just get stock toyota? Will definitely use them for flywheel though..
i just re used my old second hand head bolts there is no need for anything stronger
Why replace the flywheel bolts?
because once they are tightened and loosened they lose some integrity and may sheer.
