Page 8 of 18 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 ... LastLast
Results 71 to 80 of 174
Thread: Building a 7age.
  1. #71
    Senior Member bones's Avatar
    Apr 2010
    Brandon
    Geelong
    where did everyone get there oversized pistons from?
  2. #72
    Veteran pen15's Avatar
    Mathew
    Sutho Shire
    oversized pistons? what are you talking about? you can just use 4age pistons BT ST 16v it doesn't matter i used over sized pistons because my bores where fucked and it needed a bore and hone but if your asking where to get them any car related place can order them in i work for an engine reco company so i get them cheap
    and yes BT 20v oil pumps suck the hydro's shit themselves its better to run a silvertop or a 7a im pretty sure a 7a pump can pump more fluid than a 4a pump as the gears are thicker i can confirm this at a later date i have spare of both laying around so ill mic them up see if there is any difference
    the dyno pull to 300rwkw
  3. #73
    according to bazda the ae111 setup wont put enough tension on a 16v timing belt also...hence me changing mine to ae101 before i find out the hard way
  4. #74
    Apr 2010
    Brandon
    Geelong
    i see its just that i have seen a few people run 0.5mm bigger pistons, i clearly no nothing about building an engine so i just wanna do it right the first time. you wouldn't be able to pm me a price would you?
  5. #75
    Aaron
    killer reply 7oxin.
    figured as much with the longer block but in my head i couldnt see it making a difference if the cams are set at tdc. but yeah i know what your saying
  6. #76
    E-Famous (Remeber your roots)
    How much does he charge for one?
  7. #77
    Senior Member Adsie's Avatar
    Adam
    Birkdale
    Got mine for about $80. That was for a 20V but.
  8. #78
    Ok
    Seamus
    Milton
    I think 80 if you send him a pulley to erode, and about double that if he supplies a new one.
    ^ Clicky clicky!
  9. #79
    Adam
    Birkdale
    I just checked my old PMs and it was $87NZD and he supplied the sprocket. This was ordered before New Years.
  10. #80
    Awesome. Saves me from having to tune it when I have stock cams, and then can do adjustable cam gears with cams possibly at a later date
  1. Replies: 22
    Last Post: 5th March 2012, 10:33 AM
  2. building need parts..
    By josh.. in forum Cars or Parts Wanted
    Last Post: 31st March 2011, 09:55 PM
  3. Building a cage
    By driftke70 in forum Technical - Questions
    Last Post: 27th January 2007, 04:16 PM
  4. Building 4age
    By works510 in forum Technical - Questions
    Last Post: 6th March 2006, 05:14 PM
