Top quality service from greg at gsl! Ordered some shocks, had them the next day - cheapest prices too.
No dramas at all mate!![]()
- GSL RallySport - Ph: 1300 884 836 -
Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
- QFM Performance Brake Pads -
Also specialising in
- DMS High Performance Shock Absorbers - Monit Rally Computers -
Can I please get a postage quote for a pair of SW20 AGX rears to Brisbane 4001?
Regards,
Hi Chris,
$109 each, plus $8 shipping.
Regards,
Greg
u serious? toyota sw20 mr2 kyb agx for 109 each?
Woops, sorry, AGX would be $219 each. $109 is for Excel G.
Regards,
Greg
Or alternatively for $10 more each you can get Koni Yellow Sports.
Greg,
I would guess that the physical dimensions should be the same for the same application, but the valving and adjustability would differ. What's your view?
If it helps, it mainly road use with an occasional autocross session, drift day. Currently has Koni yellows in the back.
I'd probably match it with a set of Koni Yellows if you've got them in the rear. Being a rear engined car, the weight (and thus spring rate) won't be dramatically different between the MR2 rear and AE86 front, and you'll have enough adjustment with either the AGX or Koni Yellow to sort it out.
