hey guys up for sale i have my ke70 corolla with a 4age small port, the car isn't running but has only alittle wiring to do
dont have time for it and found a ae71 pano i would like to buy but this needs to go first
the 4age came out of a AE92 SX with 228xxxkms on it the motor had been rebuilt at 164xxxkms
well need to be complete
wiring of the motor finished
head lights
beaver panel
bumper
cluster
elec themo fan
For sale: 1983 KE70 corolla in yellow
Asking Price: NOW 2000 ono
Killometer's: think its around 230xxxkms cluster was changed
Manual or Automatic transmission: 5 Speed T50 with NEW excedy HD Clutch
Engine Type: 4AGE Small Port from a AE92 SX, has been freshened up due to a water jacked blown to outside of head so i ran a VRS kit through it, i didn't do the bottom end because i got the the AE92 SX off a mate and i saw it run, it didn't smoke and had plenty of grunt before the clutch died, head was machined and checks for hardness and was put back together with ACL Gaskets, new head bolts, new timing belt kit, new water pump, sump resealed, the flywheel was machined and a nice new excedy HD clutch was installed, all work was done by me and i can assure you i have built plenty of motors and i know what i am doing, i only use the best assembly lube from Redline, and best oil from motul.
Condition: paint is in ok condition needs a polish NO rust in the top of the rear gaurds just at the bottom rear holes in boot from spirt wing covered with 100 mile hour tape
and very little rust throughout the car
Modifications: will have Standard Wheels, kings springs out of a ef falcon in the rear and r31 skyline in the front, has Extractors with a full 2 1/4 system one muffler never heard but was done by doug at unque exhauts in bayswater he said it will sound wicked, exedy HD Clutch, vl fuel pump, dash has been dyed black, diff is winney and locked
NOTE: Corona Struts and Tacho Dash have now been taken out of sale, well have standard Struts installed
Complianced/Engineered: NOT engineered
Road Worth Certificate: SOLD AS IS
Registration: NO REG SOLD AS IS
Crash History: None that i know of
Contact: Daniel 0448 537 256
give me a call for more info
K&N Pod not in sale
