You guys serious? LOL
Did you say hi PS? I had hour sleep and was still drunk.
I always think Marv has drugs on him...
LOL. I was probs like wtf who is that. Was well out of it. You coming to the one next month?
Check the flex/twist ont he steering column bush/rubber now. It will twist like a bitch no doubt. You could make a rough one up of alu/steel with a grinder and drill too or possibly the s13 ones are the same size?
Still feels tight! Got wheel alignment tonight. Urgh 5 castor max.
I think S13 rack mounts are different?
Failed on skidpan, handbrake does not work..
It seems to have a really small oil leak? Looks to be from the cam seal (which is new?) Will check it out tomorrow hopefully.
ah 31 handbrakes haha, no idea how that shit ever passed adr
Busted my radiator last night... Was driving along highway @ 3.5k then water and steam pisses out of my bonnet, turn engine off and cut people off to pull over..
FUCK YEAH NO TEMP GAUGE.
Looks like it's busted the top tank where it joins? Had a friend bring an rb20 rad to me, zip tied it on and away I went. HG seems fine!
Went to servo to get water etc at Twoong.. Cops rock up so we just chilled and talked.. Then they come over and the lady is like.. "Looks a bit low", and I'm like " It shouldn't, It might be because of the tire profile, It has 50's.. I think it runs 60's stock" she asked when I got the wheels etc and I said that The tires were all my shop had. She then said the height was fine. Wtfffff It's 100mm at rails and like 80 at the extractors. With 55's it will be like 5mm higher?
So anyways I am sick of my axles making crazy noises? I have been told it's because I welded my centre and not spooled it?
S1/2 lights are onLooks so much better.
Cooler setup. I need to do some ducting so it gets more air...
