Results 1 to 7 of 7
Thread: tube notcher
    Timmy D
    North
    Default tube notcher
    hey guys
    looking at getting a tube notcher, any advice on what to go with?
    iv never used one so not to sure what to look out for.
    cheers
    JJ
    Corey
    Hello
    Have a look at the heavy duty JD Squared one. Seems to be the most versitile.
    Corey
    Timmy D
    North
    got any links or where to search for them, stores ect?
    JJ
    Veteran blair's Avatar
    Blair
    SEQ
    I'd say he's refering to THE BEAST:
    as the versatility is described as "Ultimate"
    i however have absolutely zero input of my own. looks like fun though!
    Adan
    Oxley Park
    Its not really that hard to make up a jig which fits into a drill press if you plan it out.
    Also, we have one at work which is a die/tool that fits into the punch and notches it that way. Its easier to use, but youd need one for every size tube you want to use.
    Mar 2010
    Simon
    Most inexpensive hole-saw style notchers will work well in notching all types of tubing, although, the difference does come in the versiltity, type of shaft bearings and mounting alternatives. A standard notcher (hole saw style) will set you back anywhere around the $200 mark, none include hole saws by the way (extra $30 odd for 1 3/4 inch or 44.5mm, cams approved diameter for primary structured cages). This will enable you to notch round tube (some models square as well) any where from 45-65 degrees of angle in straight tube only. There is a guy in the u.s who has made an adapter for these to enable notching on a bend.
    The next step up is mainly in quality and longevity of tool life. These notchers look very similar but have multiple needle bearing shaft blocks, square and round tube clamp holder which forces a bracket down to clamp the tube instead of a bolt, which damages the tube, and will always notch upwards of around 60-65 degrees. E.g Speedwerx notcher. These will set you back nearly double but will last a long time, in hobbiest use probably forever!
    Next you head into the top of the range versions of the holesaw style notcher which will do all of the above along with notching on bends and 180 degree reverse notches for those super shallow notches where the shaft holding the hole saw bottoms out before the cut finishes. E.g The beast from J.D square USA and various independant items advertised on youtube. Expect $600+
    Wont go into linisher style notchers as they usually start in the $2000+ bracket.
    Links, um JD Squared website and Speedwerx here in Aus aslo have there own website, for the Cheapie but ok for hobby stuff Hare & Forbes Machinary all over Aus.
    Jun 2013
    Ella
    Ballarat
    The jd2 notchmaster is a good solid notcher option and worth for your money.
  1. Dipsticks and tube thing
    By Golden Circle in forum Technical - Questions
    Last Post: 20th May 2012, 01:46 PM
  2. Ram Tube Option
    By wild_70 in forum Technical - Questions
    Last Post: 24th September 2009, 06:33 PM
  3. you tube vid
    By dunga70 in forum Offtopic Discussions
    Last Post: 15th March 2009, 09:50 PM
