if your desperate, use the small red female crimp connectors, you only need like 3 of them
Have got everything bolted in an ready to run but I just need a 100kw 12 pin ecu plug .... If anybody has one they are willing to part with please call me on 0403 549 943 .. Daniel
Are you saying you only need to connect 3 up out of the 12 ? If so do you happen to know what ones ?
Check other model toyotas for the plug, think maybe sv21 or similar era cars had the same sorta plugs
Sv21?
SV21 is 88-92 and I think they're yellow plug like bigport, for smallport you need a grey plug from a widebody camry 93-97 but make sure you get the right 12 pin plug as I think there's 2 very similar in size. I think I got mine from a 5SFE camry ECU. Measure the width of the plug then go to the wreckers armed with sidecutters and screwdrivers.
Shit yeah thanks a bundle mate you are a real life saver![]()
