Page 6 of 1886 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 56 106 506 1006 ... LastLast
Results 51 to 60 of 18860
Thread: Offtopic Thread 2011
  1. #51
    Gunner
    those the hectic chromies you gonna run under the headlights cowman?
    mmm cement, i wish my car was on cement, fucking working in mud pfft, what a dumb cunt i am
  2. #52
    Gunner
  3. #53
    Glenn ke_70's Avatar
    Clay
    Barossa!
    timing belt was the first thing i checked. both notches face upwards. but relitive to the crank angle im not sure?
    timing light also says timing is correct apparently?
    i suspect its mabey the vvt plugs... well see soon
  4. #54
    Veteran johl's Avatar
    Johl
    post man just rocked up. finally got my mcnsport rear coilovers. they are pretty small. should be interesting to see how low they go
  5. #55
    Dec 2010
    Cal
    Put it this way on max high they would just be legal height.
    People are saying the damper is too soft on them not sure might get some anyways.
    Cut the other door up and started on the instustion bar any idea how to get them out without cutting cause I'm a gumby and it sits tight agaist the door skin.
    I really wanna get 800kg without cage hope It won't be too hard. So far I have fierglass hatch bonnet and s fiberglass n2 kit.
    Need to get some lexan for the windows.
    Don't you like my idea johl?
  6. #56
    Johl
    yeh man i like what you are doing. i am just critical sometimes. i'm just not sure i would cut out the webbing in the rear as there isnt really anything to support the rear panels left. i think if you had a slight knock to the rear it will cause massive damage as there is no reinforcement left in this area.
    is it a track car or will it have "rego"?
    i remember reading someones build who was at 840kg with a cage from ages ago... i cant remember who it was but it was on the old forums
  7. #57
    Elite rthy's Avatar
    Leo
    Tulla
    quad headlight ae86 ftw
    then the chome wheels for the finish?
  8. #58
    Gunner
    rthy there is a few 16 inch ssr meshies on yahoo, enought to make a good sized pair.
    What bit you talking about cal, the little gay bits that go to the arch are pointless, they provide structure for the seat mounts and not much else, the reo on the other hand is critical, and not worth removing as you'll put more weight in re-enforcing it.
  9. #59
    Dec 2010
    Cal
    Check my thread in the tech section.
    Wont have rego.
  10. #60
    Elite rthy's Avatar
    Leo
    Tulla
  1. Offtopic thread 2011.
    By n2866 in forum Offtopic Discussions
    Last Post: 3rd January 2011, 09:40 PM
  2. Biggo's Offtopic Offtopic Thread
    By biggo in forum Offtopic Discussions
    Last Post: 14th July 2008, 09:19 PM
  3. offtopic thread
    By us_ae86 in forum Offtopic Discussions
    Last Post: 2nd August 2007, 01:03 PM
Tags for this Thread
