For sale is a 4agze 7 rib Long Motor i.e. complete bottom end with head, cams, cam gears, harmonic balancer. I bought this to build up a turbo motorto put into my ae71 however its taking up space and it probably wont happen. I was told that it was previously turboed, also the oil return has been modified to suit a larger hose, which also makes it look as though it was turboed. The motor looks to be in good condition, turns over freely, looks as though it has been rebuild at some point. Comes with everything pictured (minus engine stand) and also comes with the timing belt/camgear covers and backing plate and the inspection plate/cover that goes between gearbox and engine.Im after $550 o.n.o
Also have a good td04l off a wrx which has done around 120000k's no shaft play etc. in very good condition which i was going to use on this motor. $150
Bump. Also found the waterpump and housing, and some rwd engine mounts
