Results 1 to 2 of 2
Thread: AE 86 Trueno
    Dec 2010
    Shawn
    Default AE 86 Trueno
    Hi i got this car from Japan recently anyway here are the specs of this car at the moment.
    Toyota sprinter 1987 built trueno AE86 model this is the last run model.
    Model: JDM 1987 AE86 GT APEX
    KMS: NA as engine has been changed and rebuilt
    Color: silver / gold black bumpers
    Transmission Type: Manual
    Car has Power Steering
    Spec list
    Full Black Carbon fiber Bonnet with bonnet pins locks.
    TRD ducktail
    Front wide body guards fiber glass
    Engine:
    AE92 Head with AE86 block and AE101 crank
    oversized water pump pulley
    Custom extractors
    modded throttle body.
    Re-located oil filter
    Oil cooler
    8mm leads
    Interior:
    Full electronic dash (very rare)
    Nardi steering wheel
    Quality Half cage, that will be registered with
    Handbrake drift button
    All Interior is there no cracks in dash
    Gauges (all connected and work perfect)
    Oil temp
    Oil pressure
    Water temp
    Water pressure
    Oversized tacho
    Apexi SAFC
    CD/MD deck
    Wheels and Tyres:
    14 x 8 - Longchamps (front)
    14 x 9 Longchamps (rear)
    Drive-train:
    Jap spec T 50 5 speed gearbox
    Heavy Duty clutch
    TRD 1.5 Way
    Suspension:
    Front - Cusco coil over’s with an 8kg spring rate with
    camber tops
    Rear – adjustable shocks (dampener adjustable) with HD
    Springs 6kg
    Front & Rears sway bars
    front quarter guard braces
    front and rear cusco strut braces
    cusco tension rod brace
    caster rod bracket brace
    Brakes:
    Front and Rear disc brakes
    Front and Rear Slotted Rotors
    Braided brake lines front and rear
    Lights:
    car is a original trueno so its got pop up headlights. With HiD globes
    Junior Member Osaka86's Avatar
    Dec 2010
    Zeto
    Osaka, Adelaide
    Bandai, Rostrevor
    Japan, Australia
    looking nice!
    are you selling or keeping?
  1. AE-86 bits.
    By Beck in forum Car Parts For Sale
    Last Post: 19th October 2012, 09:59 PM
  2. Ae 86 sprinter
    By sprinterman68 in forum Cars for Sale (Toyota Only)
    Last Post: 12th March 2008, 11:47 PM
