Results 1 to 8 of 8
Thread: swapping front suspension?
    Khai
    Question swapping front suspension?
    hey guys finally got my short storke KYB shocks for my front end of adm ae86. I have some stiffer and lower ajps springs to go with, just curious if anything has to be modded on the front struts? or will i be able to just put short stroke shocks and shorter springs straight in/onto the struts.
    thanks guys.
    Veteran johl's Avatar
    Johl
    when i got my shocks im pretty sure i need a 30mm spacer which ajps supplied
    Khai
    i didnt buy the shocks through ajps unfortunatly so i didnt get spacers =[
    Veteran blair's Avatar
    Blair
    SEQ
    quite easy to make spacers...
    just has to be small enough Outer Diameter to sit inside the tube and big enough Inner Diameter to seat on the top/bottom of the shock properly.
    Khai
    top/bottom? ummm thats all fine just trying to find what people had used, or if someone offers them.
    Blair
    SEQ
    bottom is easier, but you introduce the chance of bottoming out the shocks. they will also sit at a lower point of the stroke.
    top needs to be a perfect fit, might need to chuck a piece of metal on a lathe or spend some time with files to get it to sit snug. gives you more stroke and means you can run lower, keeping the stroke in a higher region.
    Basically all depends on how low your gonna run the car. super low = make one for the top. anything else and probably just chuck one in the bottom for the sake of effort lol
    Khai
    bottom it is just need to find if someone bought something to use and where.
    Jake
    Northgate
    If you have sw20 shocks get one of these
  1. Swapping motors
    By Skid_Panda in forum Technical - Questions
    Last Post: 8th February 2008, 06:42 PM
  2. front suspension
    By Rich_86 in forum General Topics (No Technical Questions)
    Last Post: 19th October 2007, 05:50 PM
  3. Swapping: T series 4.1 for a 3.7 center
    By slipper86 in forum Car Parts For Sale
    Last Post: 23rd June 2007, 08:08 PM
  4. Swapping gear boxes
    By Basic in forum Technical - Questions
    Last Post: 26th April 2007, 02:54 AM
